Engine guards install help
One of the rear engine mounts is rubber. This will allow the engine to drop some when you release the front bolts even if the remaining bolts are tight.
dlhmatt has the right idea with supporting the engine with a jack and a piece of wood. DO NOT USE THE OIL FILTER AS A JACKING POINT.
Adjust the jack until the bolt can be pulled out. Even with a jack you may have to "tap" the bolts a bit, which is ok in the grand scheme of things.
Got the bolt out!! Both guards on now! Just had to keep loosening it after the nut was off! Only thing that concerns me is the instructions said to torque the engine bolts to 36 lb ft which I did and to the bottom bracket to only 9 lb ft , feel like that wouldn't be tight enough. There is a little gap where the mounting backet at the bottom meets the gaurd. Thinking its normal
That bottom bolt that holds the clamp to the frame is pretty small so you don't want to over do it.
That lower mounting clamp bracket and thin bolt does seem a bit strange (possibly weak link) to me too.
Perhaps we need to keep an eye on it from time to time that it's still tight and also not slipped or deformed.
Well I redid the install this time I used blue thread lock on the bottom bracket. So glad I tried this again before letting the dealer do it.
  Delkevic 9" Oval Install Problems. jbird06_imp 4 482 06-11-2024, 08:25 AM
Last Post: devildogdoc_imp
  Install a 6-speed trans on a 2013? amacbeth_imp 37 3,367 02-21-2023, 12:22 PM
  17 tooth CS sprocket install, comments. Bike #12_imp 11 1,012 01-03-2022, 08:30 AM
  Tail light install problem iamheero_imp 9 745 11-27-2021, 02:58 AM
Last Post: Bazbro_imp
  Engine Guard Install Question? linuxology_imp 27 1,893 07-25-2020, 08:52 PM
  Location of Engine Number on Engine? cb1100_dude_imp 2 335 05-29-2019, 01:44 PM
Last Post: cb1100_dude_imp
  You can't do that, Panier install kennyw 32 2,047 03-19-2019, 02:53 AM
  Would love some input on the install of the factory heated grips. Tim_imp 2 346 05-06-2018, 03:08 AM
Last Post: Tim_imp
  Grip install. Again. Grr. Inhouse Bob 9 696 03-29-2018, 07:10 AM
  Road Comet 2 Install letsjet_imp 20 1,368 02-12-2017, 05:51 AM
Last Post: ClassicVW_imp
