Question about oil level???
If your glass is half full.......then you are an optimist.
(05-05-2015, 01:06 AM)The ferret_imp Wrote: NOW you all know why, in my how do do your own 600 mile service thread, I say to put in 3 qts 28 oz, run it, check it, then sneak up on the upper line an ounce at a time. There is a method to my madness bwaahaaahaaa. Wink
We should all pay more attention Thumbs Up
I just checked my overflow tubes. They are dry as can be, I think I'm good.
I'll be more careful next time !!
Ferret... I did see your how to thread and it was very helpful , however , I just knew that since I had my bike really good and hot that it would all drain out ... well , I was wrong and promptly admit it ..lol ... it does NOT all drain out ... some still stays! ... Im not real worried about it as I can still see some air above in the window .. but I will pay more attention to your How-to threads....just like you said ... it really bugs me not to have the oil line perfectly between the high and low mark in the window..lol... its only 1 millimeter above but I will think often of that 1 millimeter !ROFL
Thanks
(05-04-2015, 11:31 PM)CIP57_imp Wrote: John,
I put in 4qts which fills the sight-glass, your fine.
Thanks
(05-05-2015, 01:42 AM)treytexag_imp Wrote: My sight glass is full and came from the dealer that way.
Trey they all come overfilled an ounce or so, and my understanding from talking to Honda mechanics is the reason why is they expect new engines to use a little oil before the rings get fully seated during break in. I have never noticed an oil drop in the first 600 miles, but it does make some sense I suppose.
I always use a gallon at the oil change. The procedure called out by the book calls for running the engine, then letting it sit for a few minutes (don't have the manual, so can't remember exactly how many), then checking the sight glass. When I do that, the oil is just under the top line in the window. If I then let it sit all night and check it again in the morning (without having started the engine) it's right at the very top of the window. Makes sense, since oil from the top end will slowly migrate down to the crankcase over the span of hours.
Bottom line is that mine checks out between the two lines when checked by the book procedure and it looks overfull if the bike has been sitting for hours since being run.
Same was mine and I don't worry 'bout it.
So I know, the CB doesn't run dry.Big Grin
When I changed the oil plus filter, I filled up round about 4 liters and that
fitted the deal. No oil consumption recognized over 11.000km.
Nice machine. Neither do I push my bike into higher revs when it's cold,
nor do I treat it bad, so everything works out well. It's a Honda, what more should I say?
Wisedrum
(05-05-2015, 01:48 AM)ChipBeck_imp Wrote: If your glass is half full.......then you are an optimist.
Good one Chip.
(05-05-2015, 07:18 AM)Flynrider_imp Wrote: I always use a gallon at the oil change. The procedure called out by the book calls for running the engine, then letting it sit for a few minutes (don't have the manual, so can't remember exactly how many), then checking the sight glass. When I do that, the oil is just under the top line in the window. If I then let it sit all night and check it again in the morning (without having started the engine) it's right at the very top of the window. Makes sense, since oil from the top end will slowly migrate down to the crankcase over the span of hours.
Thanks for the info Thanks
What I did. My level is right on. Thanks.
Glad top know you're "on the level" with us.... Tongue
fritz
  fuel level sensor MBZM Rai_imp 11 928 04-11-2023, 11:38 PM
  Oil Level Enzofour_imp 15 1,215 05-10-2021, 09:48 PM
  Low oil level mrded_imp 33 2,278 03-30-2021, 05:51 PM
Last Post: mrded_imp
  High oil level Mixagon_imp 15 1,152 03-22-2021, 10:37 PM
  Oil level difference between check zirconxi_imp 29 1,866 06-27-2020, 09:11 AM
Last Post: redbirds_imp
  Oil level question 562loosenoodle_imp 13 854 03-28-2019, 09:41 PM
  I have two challenges... shifting down and checking the oil level Inhouse Bob 15 1,188 02-11-2019, 01:55 PM
  Checking the oil level LongRanger_imp 27 1,591 10-18-2017, 04:13 PM
Last Post: Jeffhorn_imp
  Oil Level Sight Glass Question olekzap_imp 9 756 07-01-2016, 06:59 AM
Last Post: Ulvetanna_imp
  Oil level went to lower level? mattmcuomo@yahoo.com 6 445 01-23-2016, 03:32 AM
