Signals flash faster than emergency flashers
I do signal when I feel it's necessary. For my own safety and others. My concern about flashing too fast is only whether or not it is bad for my electrical system. Sorry if I hit a nerve Retsel.
Sent from me......
(02-23-2016, 12:23 PM)MMC_imp Wrote:
(02-23-2016, 11:45 AM)Ferrealls_imp Wrote: If the new ones are LED they'll still work, but the flash frequency is based off the circuit resistance. You'll need to add a resistor in series to correct the problem.
Exactly what I was thinking. I wonder, if I don't add a resistor, will it be bad for the system?
Sent from me......
Sent from me......
Nah. You're not introducing any new grounds or anything. The relay works on inverse time-current. The lower the current flow, the faster the flash frequency. That's all. You may burn up you flasher relay faster just because it's cycling more than stock, but that's about it for the system. The resistor will get hot when installed, so that's an annoying factor as well. You'd want to make sure to get the proper resistor to avoid excessive heat. To do that you'd need to look at the wattage on the current bulb vs. the original.
Thanks for the replies, I'm not going to bother adding resistor. It's fine like it is.
Sent from me......
  Hibeam and hibeam flash button acting up. Jgarciajr40_imp 7 737 04-01-2024, 08:13 AM
  Wire Colors for Signals, Tail Light RedRoevr_imp 10 705 05-01-2022, 06:23 AM
  Changing Placement of Rear Turn Signals eddi0_imp 9 724 06-27-2021, 03:57 AM
Last Post: Gordo_imp
  LED turn signals Jeff in OH_imp 18 1,237 11-15-2020, 07:11 AM
Last Post: FLYTYM_imp
  lazy four-way flashers Gone in 60 6 482 01-07-2020, 08:47 PM
  Wiring diagram for turn signals. kmoney_imp 21 1,286 05-06-2019, 03:42 AM
Last Post: domeular_imp
  Turn signals acting crazy Headbanger02_imp 10 747 03-30-2019, 09:58 PM
  Flash Tuning: How it Works! Red Mist_imp 13 1,029 02-09-2019, 12:46 AM
  Turn Signals/Hazard Lights - Not Blinking/Not Turning on mnm2008_imp 20 1,296 06-24-2018, 02:39 PM
  Question about Power Commander 5 and ECU Flash JohnHighlander_imp 10 642 05-02-2018, 08:20 AM
Last Post: JohnHighlander_imp
