Hibeam and hibeam flash button acting up.
I did a thread about this I think a year ago. I ended up opening it up and greasing the contacts on the hi/lo switch and that seemed to fix my issue.
Well, the issue has come up again. But this time it includes the “flash” button.
Out of curiosity does anyone have a schematic to the light switch, or just a dimenstration on how the light switch works? I was thinking of taking it apart again and putting dielectric grease where needed.
Also, a side question. How difficult is it to simply swap the switch assembly? I see a small square computer style going from the switch into the bike underneath the brake fluid reservoir. Does that simply unplug, or am I looking at an annoying job where the switch wire has to be routed all the way down the frame of the bike?
Here’s a photo I couldn’t upload due to file size so here’s some random third party think of the photo.
Does the switch simply plug into this black square?
[Image: 691534de2fc63bcd929f98c715972a49.jpg]
I believe I’m having these issues because I ride 365 rain, sleet, or snow. Albeit no snow in Florida.
I believe this is the part number, and anyone able to verify?
[url=https://www.partzilla.com/product/honda/35200-MGC-JB2]https://www.partzilla.com/product/honda/35200-MGC-JB2
The first thing you need to tell us is that you have a 2017 EX
Your original thread is here:
http://cb1100forum.com/forum/showthread.php?tid=18353
That is the correct part number for the left hand switch on a 2017, but I would check other plug in connections, where that switch plugs into the harness, and the connector to the the headlight itself. Both are inside the headlight shell.
(03-11-2024, 11:28 AM)peterbaron_imp Wrote: The first thing you need to tell us is that you have a 2017 EX
Yeah, I do that.
I would start with just cleaning the contacts inside the switches again.
Not that these are "old bikes by any means but its common in "older" bikes to have to clean the contacts in the controls/switches dur to moisture and such. I would probably avoid dielectric grease also i would just make sure they're clean/light sanding of the surface to have bare metal and you should be good for awhile
(03-12-2024, 12:32 AM)m in sc_imp Wrote: clean the contacts with deoxit15 1st.
Any other recommendations? I’m in a rural area no one has that, except guitar center which is the next city over.
I see it on Amazon may just get it on there.
I did exactly that.
Open the switch up sprayed all the contacts, and working fine.
I see some sort “powder” inside the switch. The first time I opened it I thought maybe sand from the Florida wind/air, but it almost looks like calcium or battery acid.
It’s a very small amount. Don’t think it’s battery acid as it didn’t burn my skin, though I didn’t touch it directly some just fell on me when I opened the switch up.
Whatever it is I think this is what makes the switch “stick”, or delay.
Good deal
  Turn Signal Switch and Horn Button Locations pekingduck 26 2,033 07-12-2022, 08:04 PM
Last Post: tommymck
  Instrument Cluster A & B Button Repair Phadreus_imp 36 3,172 08-17-2021, 09:09 AM
Last Post: furious_blue_imp
  Bike acting like it’s in neutral when it’s in 1st gear carlenn_imp 29 1,812 08-08-2019, 09:18 PM
  Turn signals acting crazy Headbanger02_imp 10 768 03-30-2019, 09:58 PM
  Flash Tuning: How it Works! Red Mist_imp 13 1,110 02-09-2019, 12:46 AM
  Question about Power Commander 5 and ECU Flash JohnHighlander_imp 10 734 05-02-2018, 08:20 AM
Last Post: JohnHighlander_imp
  ECM Flash vs. Front Forks (Poll) aschem_imp 16 1,180 03-29-2016, 01:31 AM
Last Post: Motogeezer1949_imp
  Signals flash faster than emergency flashers mattmcuomo@yahoo.com 12 880 02-24-2016, 03:45 AM
  ECU FLASH IN PA CIP57_imp 38 2,398 06-21-2014, 11:28 AM
Last Post: davidsargee_imp
  Re-Flash Response for CB1100 CIP57_imp 9 785 04-08-2014, 03:32 AM
Last Post: CIP57_imp
