Knock sensor? GS-911
CANBUS is a cool deal, I'm sure most all automobiles use it. It just uses a single thin data cable to every component. A lot less copper wire, reduces vehicle weight. Multiple computers throughout the vehicle communicate with the various components and data about the precise operation of each component is available.
Getting back to your thermistor, now I recall, I have 2012 Chevy van that was subject to a fuel pump malfunction advisory. GM said some of these were failing, but not all. Dealer was able to run a self-test on the fuel pump (mounted in the tank of course) to see if there were any signs of overheating. No problems were found. I believe that thermistor reads and records data on the fuel pump which is stored for some period of time and accessible. Also any time the parameters exceed a preset that is permanently stored in the ECU. So the OBD reader would show that event. That's likely the reason for a thermistor inside the tank and pump.
  O2 sensor eliminator not working on CB1100rs 2017 tory_imp 33 2,816 03-06-2026, 04:31 AM
  Oxygen lambda o2 sensor eliminator kit Davidjill_imp 4 579 11-09-2025, 06:23 AM
Last Post: AndyBeeMD
  Public Service Announcement - Speed Sensor Clip Gone in 60 7 866 10-22-2025, 02:11 PM
  How to remove O2 sensor CB1100AZ_imp 10 924 12-13-2024, 09:57 AM
Last Post: inditx_imp
  Bank angle sensor. Tezza_imp 8 785 08-06-2023, 05:57 PM
Last Post: Jurlie_imp
  fuel level sensor MBZM Rai_imp 11 927 04-11-2023, 11:38 PM
  How to remove 2013 Rear ABS/Speed sensor danieljrmurray_imp 16 1,417 06-03-2022, 01:16 PM
  HONDA Oxygen Sensor Eliminator CB 1100 2013-2016 Enzofour_imp 1 278 03-07-2021, 05:16 PM
Last Post: jtopiso_imp
  speed sensor output Lord Popgun 16 1,112 10-09-2020, 09:20 AM
  Lower engine knock airenping_imp 33 2,195 09-20-2020, 12:19 PM
