tps evaluating for ii issues
(01-04-2018, 11:28 PM)Dave_imp Wrote: Thank you Max and Sportsterdoc. My bike has never exhibited an error code, except when I unplug the EOT sensor. I checked yesterday, and I am able to unplug the connection to the TPS. I think I'll buy some contact cleaner and spray it on the connection and see if that does anything. Some members have had their idle problem corrected under warranty when the entire fuel injection was replaced; I wonder if Honda chose this repair because the TPS was faulty, and on the CB1100 the TPS is not available separately? Thank both you guys so much for all the effort you're putting into this!
That and a clean old toothbrush...but, more importantly, insure that all the connector contacts are fully seated into the connector insulator...not "floating" in the cavities.
Push each wire into the connector, to be sure that the contact retainig tab is seated.
This may have been the cause of more than one issue for members with idle issues
(01-05-2018, 12:19 AM)Houtman_imp Wrote: I think that Sportersdoc and Max put more effort in solving this problem than Honda USA does !
Thanks for the thought, but popgun has also been involved.
As for Honda or dealerships, an intermittent issue is a challenge to a mechanic living off flat rates.
What we (Max, popgun & I) have been working on should provide more method and less guessing...and hopefully reasons for each step.
Based upon Sportster experience (not that my Moto Guzzi did not vibrate just as much), poor/loose connections are the cause of many, MANY, M A N Y issues.
The CB1100 is very smooth, but a single improperly seated contact can cause alot of mischief.
Try as I may, I do not seem to be able to convince anyone to check for vacuum leaks or snug the intake clamps...but I will keep preaching! These may not be a single issue, but would still insure that they are secure.
Sorry that I missed Popgun in my thanks for solving this problem
I will buy him some drinks when I meet him someday!
[/quote]
Hi SportsterDoc. Thank you so much for all the work you're doing to help resolve this issue. Can I gain access to all of the intake clamps by lifting the rear of the gas tank, or does the tank have to be removed? Thanks to your persistence, I am going to check the clamps (asap).
(01-06-2018, 01:38 AM)Dave_imp Wrote: Try as I may, I do not seem to be able to convince anyone to check for vacuum leaks or snug the intake clamps...but I will keep preaching! These may not be a single issue, but would still insure that they are secure.
[/quote]
All eight clamps are accessible, without removing anything.
4 from the left and 4 from the right.
To check mine, I used a 1/4" drive ratchet, 6" extension with a 8mm socket.
If the bolt heads (combo 8 mm/#2 Phillips) are not exactly at 12 o'clock, a universal joint may help.
No need to over-tighten, just use a couple fingers on the wrench, close to the ratchet.
Dave, the clamp screws are easily accessible. Go look, you don’t have to remove anything. You do 2 sets from one side, then move to the other side for the other 2 sets. 4 screws total.
Sorry Doc, I guess you posted while I was typing.
(01-06-2018, 01:57 AM)Lord Popgun_imp Wrote: Dave, the clamp screws are easily accessible. Go look, you don’t have to remove anything. You do 2 sets from one side, then move to the other side for the other 2 sets. 4 screws total.
No problem-been there and done that!
Should get in about 100 miles today, which will take the odometer close to 3,000 miles in 2 months...time for chain lube #5.
Going to visit my dad in SoCal, next week, so the rain predicted (there and here) will not affect riding, since the CB will be garaged for a few days, anyway.
Our roads are covered with snow and ice. I’m not even taking the car anywhere!
popgun
I got 140 miles on the tank, today, before the last fuel gauge segment started flashing and indicating 37 miles remaining.
Came back with 3018 miles on the odometer.
Might be my last ride to Mt. Charelston for a while. It has been comfortable at 8,500 feet, even with a little snow alongside the road, in northern exposure shade.
This next storm will probably create a lingering ice situation for some time after. Kyle Canyon and Lee Canyon have areas of 6% to 8% grades.
URGENT - WINTER WEATHER MESSAGE
National Weather Service Las Vegas NV
248 PM PST Sat Jan 6 2018
NVZ018-019-071200-
/O.NEW.KVEF.WS.A.0001.180109T1200Z-180110T0600Z/
Sheep Range-Spring Mountains-Red Rock Canyon-
Including The Town Of Mt Charleston and Red Rock Canyon
...WINTER STORM WATCH IN EFFECT FROM LATE MONDAY NIGHT THROUGH TUESDAY EVENING ABOVE 7000 FEET...
* WHAT...Heavy snow possible. Plan on difficult travel conditions.
Total snow accumulations of 6 to 12 inches, with localized
amounts up to 18 inches possible.
* WHERE...Sheep Range and Spring Mountains.
* WHEN...From late Monday night through Tuesday evening.
* ADDITIONAL DETAILS...Significant reductions in visibility are
possible.
SportsterDoc may have just solved the high/low idle mystery! I checked the hose clamps on the throttle bodies today and all eight were loose! Two of them I turned the screws about three full revolutions before achieving an acceptable tightness! I rode the bike about 100 miles after tightening the clamps and it ran perfectly! Most of the miles were on the freeway, but I came to a full stop and put the bike in neutral no less than twenty times today, and each and every time it immediately returned to a perfect 1050 RPM idle! Before I can declare my idle issue is completely cured I must put more miles on the bike, and do some in town, slow speed, stop and go riding, and for a thorough test, I need to perform the in town riding in elevated temperatures. I will perform addition tests ASAP (hopefully next weekend), and report back. I urge any of you guys who are experiencing the idle problem to check your throttle body hose clamps, as SportsterDoc has been recommending.
Dave, I hope that solves it for you.
  Headlight High Beam Issues omarj_imp 5 518 01-21-2021, 11:07 AM
  2013 Starting Issues BackroadsRider_imp 6 574 03-10-2019, 10:45 AM
Last Post: flynrider
  Idle issues Macenthor_imp 4 399 01-03-2017, 11:56 PM
Last Post: johnf514_imp
  Guhl Motors and ECU Re-Map for DLX / EX with Idle Issues beardyweirdy@me.com_imp 11 823 12-22-2016, 12:40 PM
Last Post: Retsel_imp
  New Honda ECU Software, Idle Issues and a Re-Flashed ECU beardyweirdy@me.com_imp 15 1,204 10-27-2016, 03:11 AM
Last Post: StefanS_imp
  Shifting issues holy666diver_imp 18 1,153 03-28-2015, 11:09 AM
Last Post: ClassicVW_imp
  battery /charging system issues dlhmatt_imp 25 1,714 04-15-2014, 11:59 PM
Last Post: dlhmatt_imp
  Possible quality control issues the Ferret 25 1,758 03-13-2014, 02:58 AM
Last Post: Red Mist_imp
