Lower bike
If you do go with shorter rear shocks you might want to lower the front end as well to stay close to the same rake & trail. On some bikes you can loosen the pinch bolts in the triple trees and raise the fork tubes in them up to maybe a 3/4 to one inch or so. That would lower the front by that much without disassembling forks to install shorter springs inside them.
(04-03-2018, 10:56 PM)reinie_imp Wrote: If you do go with shorter rear shocks you might want to lower the front end as well to stay close to the same rake & trail. On some bikes you can loosen the pinch bolts in the triple trees and raise the fork tubes in them up to maybe a 3/4 to one inch or so. That would lower the front by that much without disassembling forks to install shorter springs inside them.
I'd go for the lower seat (in fact I may do soon). I woudn't alter geometries, nor ride height (ground clearance, rake, antisquat, etc will/can change).
I too have a 30 inch inseam and the stock height wasn't bad unless there was gravel under foot when stopped/stopping. I lowered my 14 Std by installing 335mm shocks and raising the forks 7/8ths inch in the trees. The bike has the proper rake and trail and handles better than when I had only lowered the rear. If you use a lower seat you might cramp your leg room. I have a Corbin Gunfighter and Lady and my knees are slightly more bent.
Forgot to add that I had to shorten the side stand after lowering. I cut out 3/4 inch under the return spring hook and welded the foot back on. Restored the original lean and now I can walk away comfortably, without worry.
+1 on getting your seat cut down as a first step. Here's a pic of my CB750 seats - the one in front I pulled the cover and shaped the foam for my custom build. I brought the reshaped seat to a local auto upholstery shop. They covered it to my specs for ~$160. You can see the difference compared to stock - I took it down more than an inch.
[url=https://postimages.org/]
Here's my 500 seat done by the same shop for the same price:
The trick is finding someone who knows how picky us bikers are about how our machines look!
  Lower engine knock airenping_imp 33 2,075 09-20-2020, 12:19 PM
  Lower suspension apehair_imp 3 356 08-26-2019, 11:51 AM
  Outside lower fork tube diameter Mscb1100_imp 5 513 01-12-2018, 10:34 AM
Last Post: Aussieflyer
  Lower Cover instrument panel linuxology_imp 5 432 11-01-2016, 10:19 AM
  Perhaps a sprocket change for lower revs? meowguy_imp 17 930 09-26-2015, 10:10 PM
  Lower Footpegs ? rocket_imp 15 1,139 02-04-2015, 02:53 PM
Last Post: bustin dailey_imp
  Lower Rear Brake Pedal ? rocket_imp 11 661 12-07-2014, 09:34 AM
Last Post: rocket_imp
