Lower Footpegs ?
Although both my knees have been replaced with Titanium & Polyethylene (true), they still ache a little while riding. Any suggestions on who makes a good set of lower footpegs for the CB1100 ? Thanks, Rocket
Do a search as a couple people have votten creative with different ideas on how to do it.
I really like my Vario foot pegs from Germany, have them on all of my four bikes.
I just ordered a set of these. A bit pricy and I'm still waiting on delivery I ordered the 30mm with the supergrip pegs http://www.whaccessories.com/FootPegLoweringKit.htm
My first set was the 30 mm ones but I changed them and all the others I bought after them to the 23 mm ones.
It all depends on YOU !
I have lower footpegs.
http://www.knightdesignllc.com/Products/..._Pegs.html
I love the height, the only issue is that my footbrake is too high. I've tried adjusting to no avail... I still need it another inch lower. The shifter adjusted plenty, it was easy to get perfect..
If I can figure out the brake pedal... maybe modify it slightly or figure out what I am doing wrong with the adjustment, I will be totally happy. The footpegs are good quality, still flip up, and without the bolts on the bottom like the factory pegs the clearance is about the same as factory height pegs.
I emailed these guys: http://www.whaccessories.com/Foot-Peg-Lo...-Honda.htm
to see what they offer in the way of extensions for the brake pedal side. That would likely solve my problem entirely.
With the lower pegs and an airhawk my CB is comfortable for my 6'4" frame even on long highway trips.
I have the same issue with the knight design…the brake pedal is to high. The pedal has reached its adjustable limit as the push rod is bottomed out against the brake pedal/lever. I'm considering buying another push rod, cutting it shorter and using a thinner jam nut on the linkage. It may give me just enough travel to get the brake where I want it.
Kuryakyn highway pegs are a good way to add some pegs for stretching. I'm disabled with lots of body pain and have made my bike comfortable. Just fabricate a small plate with three holes in it and use the case saver attachment bolts.
What about using higher seat?
(01-06-2015, 09:16 AM)VTR1000F_imp Wrote: What about using higher seat?
That's the best solution, get a higher seat. By the time one buys another brake lever, cuts, weld and gets it right along with the lower peg system, a higher seat is within buying costs. .02
  Anti-slip 1 piece footpegs Transport_imp 13 1,078 02-27-2024, 05:59 AM
  Lower engine knock airenping_imp 33 2,406 09-20-2020, 12:19 PM
  Lower suspension apehair_imp 3 388 08-26-2019, 11:51 AM
  Lower bike bikerpipes_imp 13 970 04-13-2018, 06:57 AM
Last Post: Perry_imp
  Outside lower fork tube diameter Mscb1100_imp 5 535 01-12-2018, 10:34 AM
Last Post: Aussieflyer
  Lower Cover instrument panel linuxology_imp 5 464 11-01-2016, 10:19 AM
  Perhaps a sprocket change for lower revs? meowguy_imp 17 1,011 09-26-2015, 10:10 PM
  Lower Rear Brake Pedal ? rocket_imp 11 734 12-07-2014, 09:34 AM
Last Post: rocket_imp
