Lower Rear Brake Pedal ?
I've installed lower foot pegs. The rear brake pedal will not adjust low enough for a comfortable position. Aside from cutting & welding, has anyone found an alternative pedal that rests lower that the stock unit ? Thanks, Rocket
By adjusting the rod? You can also pull the pedal off the shaft and re-position it some too. Other than that, I got nothing Smile
The brake pedal doesn't work that way. It is attached to the peg plate with a clip and pivots there.
I've always raised my seat. Tried the footpeg mod on my 919 and the brake did not feel right either. Then sat on the new VStrom 650. Lots of room there. Taller bike but it works. Just not my cup o tea.
(12-02-2014, 05:31 AM)Randy B_imp Wrote: The brake pedal doesn't work that way. It is attached to the peg plate with a clip and pivots there.
Randy,
Guess I should have checked the service manual...Sad
I thought I had read that someone had moved it, but I guess that was the shifter.
Randy,
Randy,
Yeah, the shifter can be moved, but the brake pedal can't.
I found myself wanting to lower the brake pedal too, wish there was a way.
Perhaps it is possible to take the brake pedal of the bike , heat it and bend it to your liking.
You can always put some chrome paint on it to cover the discoloration from heating the part.
I would suggest purchasing a lever and try bending or modding that one, just in case it gets screwed up one could still ride.
gossman: That's my plan "B" if no one has a better idea. Don't know how much they are from Honda, but I'll find out this winter. I'll cut & weld one to make it too low. That way I'll have enough adjustment in the future.
As a notice to anyone trying to lower the peddle with the adjuster: I found that a little extra twist of the adjuster will cause the threaded adjuster to contact the peddle & make it stick. There has to be a little space there or you could experience a locked-up brake at the worse time. Check for smooth operation of the peddle after adjusting & before you ride. Rocket
  Rear brake pad replacement LongRanger_imp 39 3,465 05-03-2025, 10:45 AM
Last Post: Delphisa
  Rear Brake Pedal Adjustment Gone in 60 12 1,100 04-04-2024, 08:18 AM
   Rear brake pedal Mixagon_imp 28 2,126 08-06-2022, 07:29 PM
Last Post: Mixagon_imp
  Rear brake pad thickness. 17-CB-002 4 441 06-18-2022, 12:42 AM
Last Post: 17-CB-002
  rear brake question Crossfire_imp 12 841 02-18-2022, 03:02 AM
Last Post: bvictory_imp
  Rear brake rotor and new pads Sandhog_imp 13 926 01-08-2021, 04:51 AM
Last Post: ethan.phan613_imp
  Lower engine knock airenping_imp 33 2,083 09-20-2020, 12:19 PM
  Rear brake installation? White Dog_imp 9 794 07-27-2020, 02:48 AM
  Brake Pedal Adjustment White Dog_imp 11 788 05-28-2020, 12:44 PM
Last Post: White Dog_imp
  Rear Brake "clunk" iogear99_imp 3 346 04-25-2020, 01:47 PM
