Check engine lights up. Not blinking
(05-03-2018, 02:31 AM)SportsterDoc_imp Wrote:
(05-03-2018, 01:04 AM)itstuantran_imp Wrote:
(05-03-2018, 12:20 AM)johnf514_imp Wrote:
(05-02-2018, 05:48 PM)itstuantran_imp Wrote: Mine is RS 2017 with 27,500km. Just had the check engine light coming up without blinking on the way home from work yesterday.
Bike running without any issue but just the yellow check engine indicator on. I'm wondering if anyone experience this, please share. Thanks
Wait, how did you rack up so many kms on a 2017 already? Well done.
Smile, im man of move
(05-02-2018, 05:56 PM)Cormanus_imp Wrote: Someone with a factory service manual may be able to tell you how to determine what fault caused it. Without knowing that, I wouldn't ride it except slowly to the dealer or a qualified mechanic.
An addendum: things may different on the 2017RS, but the Owner's Manual for the 2010 bike says the engine (or PGM-FI) malfunction indicator lamp,
Quote:Lights when there is any abnormality in the PGM-FI (Programmed Fuel Injection) system. Should also light for a few seconds and then go off when the ignition switch is turned ON and the engine stop switch is at ⟳ (RUN).
If it comes on at any other time, reduce speed and take the motorcycle to your Honda dealer as soon as possible.
Thanks
MIL on= DTC is set = retrieve it and fix it accordingly.
MIL on indicates MPI/emission (if RS has PCSV) malfunction, whether history or present.
Don't experiment..
Good luck
pb
Don't experiment..
Good luck
pb Thanks but this is beyond my own self service Smile
The CEL will illuminate steady at RPMs above 1700 or with sidestand up.
It's on steadily when turning the key on and either at idle RPMs at 1400 or above 1700. I kept on riding for 2 days and try to notice any abnormal signs but none so far but the CEL
Turn ignition switch on, with stop/run switch in run mode, without starting the engine.
If ECM has stored DTC, the CEL/MIL will illuminate 0.3 seconds, go off, then start blinking code.
If no stored DTC, CEL/MIL will illuminate and stay on until after engine is started, per the FSM.
Tuan, where in Vietnam are you located?
Thanks SporsterDoc, i've done as said but it just stays illuminated, no blinking. just like you turn on the light and leave it there Big Grin
i'm going to bring it to service tomorrow for better diagnostics. I live in Vung Tau city, which is 100km east of Ho Chi Minh city.
(05-03-2018, 03:52 AM)peterbaron_imp Wrote: Mine is RS 2017 with 27,500km. Just had the check engine light coming up without blinking on the way home from work yesterday
...something not clear...'17 RS with 27K, MIL on when not riding?????????????? or when riding....how was it at the beginning????
Huh
pb
Well, i've been riding it since fresh purchase without any issues and the MIL on when ODO clocks at 27k km. MIL on when i turn on the key and stay. It's supposed to go away after illuminating for a while but it's now stay illuminated all the way
Assuming you tried to read the DTC correctly (make sure the sidestand is down) it could be a couple of things and may be hard for a non-technician to find.
You dealer will connect the HDS (Honda diagnostic system) to the DLC (Data link connector) and read any codes. If the MIL light is on and there are no codes it may be a fault in the MIL circuit.
popgun, is the DLC the thing the gear indicator pugs into?
Yes it is Cormanus
Thank you.
Found the culprit Big Grin. Oxygen sensor No 1 faulty (RS has 2 sensors) once the tech guy hooked up on his laptop. Replaced the sensor and the CEL gone immediately.
Thanks all for the inputs.
Thumbs Up
A failed #1 O2 should have blinked a 21 DTC: Two 1.3 second blinks and a 0.5 second blink.
(05-03-2018, 02:09 PM)Cormanus_imp Wrote: popgun, is the DLC the thing the gear indicator pugs into?
On a 2014, the DLC (data link connector) has a dummy cap over the bl/w, br, o/w, g wires. The gear indicator is fed by y, br, rw, bl, gn wires.
Is it different on the 2017?
(05-04-2018, 12:30 AM)SportsterDoc_imp Wrote: A failed #1 O2 should have blinked a 21 DTC: Two 1.3 second blinks and a 0.5 second blink.
Is it different on the 2017? No idea but no blinking at all, just stay illuminated.
(05-03-2018, 10:37 PM)itstuantran_imp Wrote: Found the culprit Big Grin. Oxygen sensor No 1 faulty (RS has 2 sensors) once the tech guy hooked up on his laptop. Replaced the sensor and the CEL gone immediately.
I am glad for your easy fix !
Photo First Check Engine Light Ever on a Bike doug1976 2 239 01-14-2026, 06:47 PM
  Check your clips! Gone in 60 3 638 07-01-2025, 11:27 AM
  Basic Maintenance: Daily Check rdprdp01 17 1,423 03-01-2025, 02:52 AM
  Time to check the air cleaner! The A-man 6 694 08-22-2024, 09:39 AM
  Sound check what wrong tory_imp 3 435 03-30-2022, 12:33 AM
Last Post: 1973cb750
  Valve check? Phat Ham_imp 26 2,031 01-13-2021, 12:36 PM
  Oil level difference between check zirconxi_imp 29 1,908 06-27-2020, 09:11 AM
Last Post: redbirds_imp
  cam chain check max 0 194 04-22-2020, 08:26 AM
Last Post: max
   Turn lights would not work Ennsync_imp 15 1,141 01-02-2020, 02:02 PM
   Engine light Blinking tory_imp 25 1,923 12-04-2019, 10:38 PM
