Check your clips!
Not sure if I shared this little tech-tip or not. Recently while giving my bike a good going-over and engine detail, I noticed that the protective plastic-dip coating on the clips that secure the wire bundle that runs under the right side of the engine was peeling off due to age and engine heat.
I removed both of the clips and peeled off the rest of the coating. Then, I put some heat shrink tubing on the clips to make a new protective coating, and reinstalled the clips. An easy fix. Might want to give your clips a look-see!
Attached Files Thumbnail(s)
thanks for the tip Gone in 60. good idea.
-tdbru
(06-25-2025, 01:49 PM)Gone in 60 Wrote: Thanks for the tip, I'll check my bike today. Cute bell.
Thanks. It's from my wife and says "Please ride safe. I need you here with me."
As opposed to the one she bought for my other bike that says "Don't F$&%n Die"
Photo First Check Engine Light Ever on a Bike doug1976 2 226 01-14-2026, 06:47 PM
  Basic Maintenance: Daily Check rdprdp01 17 1,368 03-01-2025, 02:52 AM
  Time to check the air cleaner! The A-man 6 668 08-22-2024, 09:39 AM
  Sound check what wrong tory_imp 3 416 03-30-2022, 12:33 AM
Last Post: 1973cb750
  Valve check? Phat Ham_imp 26 1,864 01-13-2021, 12:36 PM
  Oil level difference between check zirconxi_imp 29 1,808 06-27-2020, 09:11 AM
Last Post: redbirds_imp
  cam chain check max 0 183 04-22-2020, 08:26 AM
Last Post: max
  check engine light stays on, on my 2017 Houtman_imp 51 3,330 07-27-2019, 01:27 PM
Last Post: itstuantran_imp
  CB going in for Valve check/adjustment Frulk_imp 9 689 03-29-2019, 09:50 PM
  Check engine light/codes Carguy1959_imp 17 1,092 08-24-2018, 03:00 PM
