cam chain check
Who else is taking notes on the length of the cam chain?
When i got the hornet 900 i figured i might as well take a note on the status of the cam chain tensioner, very easy to do and an indication of how the chain is wearing or not.
Simply checking how much turns out i could rotate the screw inside and writing that down would provide some indication of it's condition, it turned out it was 2,5 turns in out of five possible turns, so i wrote that down with the kilometers at the time.
Just done the same thing with the cb1100, it measured 3,3 turns in from when it came to a stop when untensioned all the way as is recommended when checking the valves.
and wrote it down on the sheet with the valve clearances with the km's on the dashboard.
Undid the m6 bolt with the alu washer with an 8mm spanner and turned the inner screw with my copper special tool i made to mount the tensioner if required.
Photo First Check Engine Light Ever on a Bike doug1976 2 227 01-14-2026, 06:47 PM
  Check your clips! Gone in 60 3 611 07-01-2025, 11:27 AM
  Basic Maintenance: Daily Check rdprdp01 17 1,372 03-01-2025, 02:52 AM
  Time to check the air cleaner! The A-man 6 671 08-22-2024, 09:39 AM
  Sound check what wrong tory_imp 3 418 03-30-2022, 12:33 AM
Last Post: 1973cb750
  Valve check? Phat Ham_imp 26 1,887 01-13-2021, 12:36 PM
  Oil level difference between check zirconxi_imp 29 1,832 06-27-2020, 09:11 AM
Last Post: redbirds_imp
  check engine light stays on, on my 2017 Houtman_imp 51 3,352 07-27-2019, 01:27 PM
Last Post: itstuantran_imp
  CB going in for Valve check/adjustment Frulk_imp 9 693 03-29-2019, 09:50 PM
  Check engine light/codes Carguy1959_imp 17 1,098 08-24-2018, 03:00 PM
