Aluminum fork tube oxidation ?
Mr. Clean "Magic Erasers" (formaldehyde-melamine-sodium bisulfite copolymer) are truly magical. Apparently they are safe to use, but don't eat them.
I wear nitrile gloves when working with any solvents, cleaners, polishes, or petroleum based products. Anything strong enough to take rust or other oxides off of metal can't be good for the skin.
My most respected polish is Autosol. I only use it if everything else fails. Nothing else will turn a rag so black when cleaning alloys. Makes me wonder what it is doing to the metal at the molecular level.
(01-09-2019, 06:35 AM)Nortoon_imp Wrote: I wear nitrile gloves when working with any solvents, cleaners, polishes, or petroleum based products. Anything strong enough to take rust or other oxides off of metal can't be good for the skin.
Correct. Protect and moisturize the skin. It will crack with most said liquids and even the Magic Eraser.
I believe the black rag is the resultant reaction the compound has with the alloy and/or alloy surface oxides. Some of these type of compounds also "seal" the surface with a type of polymer that protects it from subsequent oxidation. Some can even survive (i.e. not burn) the surface heat of the exhaust port pipes. I know this because for the first time (all of 2018) my headers did not turn blue/purple/brown.
  CB1100ex Tires pressure, when changed tube to tubeless tory_imp 10 934 10-09-2023, 07:51 AM
  2017 tube type tires Mafd2_imp 4 502 02-08-2023, 01:10 PM
  Fork tube rust melfl_imp 8 798 12-23-2022, 04:41 AM
Last Post: redbirds_imp
  Fork Tube hex head bolt tool fitment ? bflint 8 775 11-30-2020, 06:24 PM
Last Post: jtopiso_imp
  fork overhaul vs. fork replacement? misterprofessionality 20 1,883 09-20-2020, 07:13 PM
Last Post: DBM_imp
  Fuel Tank overflow drain tube. zirconxi_imp 11 983 05-29-2020, 11:36 AM
Last Post: LakeWylieJoe_imp
  Throttle tube easy to fit? Buzzard Biker_imp 9 712 02-28-2020, 11:21 PM
Last Post: Bazbro_imp
  Outside lower fork tube diameter Mscb1100_imp 5 549 01-12-2018, 10:34 AM
Last Post: Aussieflyer
  WM Aluminum Fairing Help Hondahawkrider_imp 7 750 08-27-2017, 05:36 PM
Last Post: buckwheat_imp
  Quick question... "drain tube"? quietguy_imp 4 369 01-08-2016, 01:16 PM
Last Post: quietguy_imp
