Oil level question
I have never lost a mysterious measurable amount of oil on the CB. If you are burning any, inspect the final exhaust ports for oily build-up. Flat black carbon build-up might be present, particularly on cold morning start-ups as condensation works its way out of the cold final pipes. But oil is heavier, shinier spotting at the muffler end. A more direct way is to inspect the spark plugs for oil deposits. The only other way out is a seal leak, but that should be much more obvious. All else being equal, fluctuations in oil level could mean more is stored up in the engine, but I am having a tough time selling that to myself since oil will eventually find its way back to the sump.
Checking it in the same exact place, facing the same direction, is important. What may look level to the naked eye often is not. For example, my driveway looks pretty level, but I get drastically different readings depending on which direction it is facing parked there. It slopes to the right basically.
Interesting comments about ground level Thumbs Up Thumbs Up
Yes indeed, gravity may not be your friend when checking oil level.
(03-28-2019, 08:11 PM)Rocky_imp Wrote: Interesting comments about ground level Thumbs Up Thumbs Up
Lol - maybe a nearby unstable singularity? Smile
  fuel level sensor MBZM Rai_imp 11 934 04-11-2023, 11:38 PM
  Oil Level Enzofour_imp 15 1,225 05-10-2021, 09:48 PM
  Low oil level mrded_imp 33 2,293 03-30-2021, 05:51 PM
Last Post: mrded_imp
  High oil level Mixagon_imp 15 1,165 03-22-2021, 10:37 PM
  Oil level difference between check zirconxi_imp 29 1,875 06-27-2020, 09:11 AM
Last Post: redbirds_imp
  I have two challenges... shifting down and checking the oil level Inhouse Bob 15 1,205 02-11-2019, 01:55 PM
  Checking the oil level LongRanger_imp 27 1,608 10-18-2017, 04:13 PM
Last Post: Jeffhorn_imp
  Oil Level Sight Glass Question olekzap_imp 9 758 07-01-2016, 06:59 AM
Last Post: Ulvetanna_imp
  Oil level went to lower level? mattmcuomo@yahoo.com 6 448 01-23-2016, 03:32 AM
  Question about oil level??? Johnboy_imp 24 1,534 11-06-2015, 01:13 PM
Last Post: kmoney_imp
