clean front sprocket
Good decision, Bronzaar. You actually have to remove the shift lever and then the cover. When you do, you'll discover the clutch slave cylinder and yet another cover which have to be removed as well before you can get at the from sprocket. If you want to get the chain off, you probably also have to loosen the rear axle and slide the wheel forward.
(04-04-2019, 07:21 AM)Bronzaar_imp Wrote: ok thanks for the answers guys!
now i know i don't have to bother that much i won't do it either.
I guess the fact that it's my verry first bike ever that makes me want to be sure i do everything right to be safe. i'm verry new in motorcycles.
The guy in a Honda shop in Belgium who told me he does it every weekend must be a maniac. Or he want me to buy lube bottles as much as possible. Smile
When i bought it it had 30.000KM now it has 34.000. In the shop they said to come back at 36.000 for a first check up. I will ask them at that time to teach me about punch marks and splined shafts and such. on the spot and in dutch it will go easier.
For now i first drove a bit after work, then cleaned the chain with product i bought for this, a TON of filth came of, after it was clean i lubed it . let it rest 2 hours and then drove a bit again. done.
I would have to agree with that. Sounds like a psychiatric disorder. I used to date a gal that used to scrub the inside of her dishwasher clean every week. Huh Huh
Mine never gets dirty if I don’t rideBig Grin
I would have to agree with that. Sounds like a psychiatric disorder. I used to date a gal that used to scrub the inside of her dishwasher clean every week. Huh Huh I think that I married her !
Can I have her cell number.... I have to clarify a few thingsAngel
Cleaning behind the sprocket cover every week does seem a bit excessive - to say the least ROFL
To be honest, I afraid to open up the front sprocket area. After seeing it, I might want to clean it more often. (like a curse)
For three years I lubed the chain of my CB500XA after every second day ride with chain oil that was suppose to be none fling. Someone had suggested placing a small magnet on the chain before rotating it so you tell when the lubed part came around. After the second one disappeared I decided to remove the front sprocket cover to retrieve them.
OH MY GOD! Everything was packed with grit and grease.
Took a lot of popsicle sticks and paper towels to get the worst of it out. Took a spray can of GUNK engine cleaner and my spray washer to get the rest off. The curb had a long prism coloured puddle all the way down to the sewer cover where the two missing magnets found a home. Good thing the neighbourhood tree hugger was not around to see that.
I now use chain wax. Unlike chain oil this stays on the chain. No more grubby mess on the chain, chain guard, back wheel, and front spocket.
Mine got sorta cleaned when I replaced the chain and sprockets at 36,909 miles.
I use chain wax as well. Matter of fact this reminds me to spray some on before I ride down to the local coffee shop n about 30 minutes. I use it every 500-600 miles or if ridden in the rain.
  Chain and Sprocket Options? Yata-Garasu_imp 22 1,940 12-23-2024, 04:47 AM
  Chain or sprocket problem ? The Gecko_imp 14 1,188 07-30-2024, 10:05 AM
  Front sprocket bolt cant be moved misterprofessionality 55 4,404 03-13-2023, 12:18 PM
  Front drive chain sprocket wear 1970Cadillac_imp 15 1,134 11-29-2022, 07:49 AM
  17 tooth CS sprocket install, comments. Bike #12_imp 11 929 01-03-2022, 08:30 AM
  Clean engine cutoff, starter buttons mustang462002_imp 3 374 03-19-2021, 04:13 AM
Last Post: whizzle_dizzler_imp
  How To :19 tooth front, and now, a 37 tooth rear sprocket on 2013 pekingduck 60 3,873 03-07-2021, 09:32 PM
  Another chain and sprocket question bflint 20 1,464 10-13-2020, 01:00 PM
Last Post: tod.branko_imp
  Alloy Sprocket woes Ninemeister_imp 22 1,566 09-24-2020, 09:23 AM
Last Post: Ninemeister_imp
  Broken rubber on front sprocket zirconxi_imp 7 526 05-24-2020, 11:17 AM
Last Post: zirconxi_imp
