Clean engine cutoff, starter buttons
Hello,
I lost power on I-495 in a traffic jam after accidentally touching the engine cutoff.
Took me about 3 min to figure it out which really felt like half an hour with heavy traffic behind me.
I've been having issues with the button. But clicking on and off and pushing it in made contact.
I've decided that I'm done having this issue. LOL
I've taken apart the button before but did not see it readily accessible to expose the contacts. I've cleaned it with contact cleaner and it helped. But the issue returned this season. Has anyone torn the button apart to clean it?
I've placed the order for a new button about $90 but before it comes I'd like to try to clean it.
Thanks!
2014 CB 1100 about 10k miles.
(03-17-2021, 04:22 AM)mustang462002_imp Wrote: Hello,
Thanks!
I can't remember if i did it in the CB or my kawasaki but there is a little spring in there that keeps it taught. Make sure its where it should be.
Thanks for the reply! I'll buy another switch and experiment on the one I take off.
It's always a good thing to break down and clean the insides of the switches once in awhile. Corrosion and gunk will build up on the contact points, potentially causing reliability issues like this. Also, after time, old grease inside the switch housing will start to stiffen up and slow the movement down on certain parts like the signal switch. "Make your bike feel new again with this one simple trick!"
  Help from the hive mind: Intermittent Starter Issue (2017) JRD 10 540 01-30-2026, 02:16 PM
Last Post: JRD
  Just in case anyone is interested in what the inside of our starter looks like… PowerDubs_imp 14 1,142 07-14-2024, 05:05 PM
  Heat soak starter coil, or weak battery? zirconxi_imp 36 2,507 10-11-2021, 12:58 AM
  Need a starter switch but none available Kdogg2077_imp 11 942 07-05-2021, 01:56 AM
  Location of Engine Number on Engine? cb1100_dude_imp 2 332 05-29-2019, 01:44 PM
Last Post: cb1100_dude_imp
  2014 Start - Cutoff Switch Question deltamark 16 1,258 04-18-2019, 06:23 PM
Last Post: flynrider
  clean front sprocket Bronzaar_imp 22 1,511 04-08-2019, 04:49 AM
Last Post: Bronzaar_imp
  What does everybody use to clean their headers? misterprofessionality 30 1,992 04-27-2018, 12:49 PM
Last Post: NightRider_imp
  How do I clean the crankcase breather? Sfomoto_imp 10 760 05-04-2015, 06:42 AM
Last Post: Novice_imp
