Engine dies when I put in 1st gear (yes, clutch is engaged)
What!? Technical stuff on the agenda too?
How ate up is it when you wonder the outcome of members issues while on vaca?
Mate, it's tragic. But then you're in a car not on a bike. A man of your sensibilities will be getting all the vicarious hits he can!
True that lol
(07-28-2015, 07:24 AM)13cb1100_imp Wrote: Frustrated! Hope someone has an idea...
Bought a new 2013 CB1100, now have 375 miles on it. Bike was dealer showroom for almost 2 years. Everything stock.
Start bike...starts instantly after sitting all day at my work, outside. Pull clutch in, put in 1st gear, engine dies. Many times I've done this, put in neutral, re-start engine, pull in clutch, 1st gear, dies. However, once I turn the key off, wait a minute, try again, it works fine.
If this was a neutral safety switch, I'd think the bike would not start, or not recognize its in neutral when starting. However, it seems the clutch does not engage...like I'm putting it in gear w/o the clutch. Yes, i adjusted the knob on the clutch lever but did not matter. My search here yielded nothing.
This has happened twice, 2 days in a row...both times after riding to work, sitting 8 hours (both me and the bike...hehe!), then starting it for ride home (15 miles each way).
Ideas? I'm stumped. Dodgy
My bike too is a 2013 with 375 miles. While riding today, bike lost power to engine while riding up in the mountains. Stopped, pointed bike downhill, and coasted for 100 ft. Put bike into into neutral it started, put it into gear it died. Tried again in neutral and starts, then shift to 2nd, and it keeps running so I head home. Get home everything is OK, does not exhibit symptoms from 30 minutes earlier. I am stumped.
check the kickstand switch
Only 385 mile! If switch is not the issue, put some Tecron in the tank with pure fresh gas, and get yourself some yeeha.
(08-23-2015, 08:11 AM)gossman_imp Wrote: check the kickstand switch
Second that.
Second that.
Second that.
To: Electronic experts
Help
Can I just bypass it altogether? If so, how?
Would ride more, but ruptured two discs in upper back so riding has been limited. Good news is that it is feeling much better.
Second that.
Second that.
Help
I would guess that it is a normally open switch and to bypass would require splicing two wires together at the switch. I don't have a service manual in front of me to verify though.
  CLUTCH FLUID CHANGE SUPERCRUZ_imp 15 1,319 12-24-2025, 11:14 AM
  Replace clutch Lever Davidjill_imp 10 1,002 02-06-2025, 01:27 AM
  Clutch Plates finally going? misterprofessionality 12 1,084 11-22-2024, 07:49 AM
  Clutch fluid change CB1100@2013: photos valkyrie_rider_imp 0 250 02-13-2024, 10:27 AM
Last Post: valkyrie_rider_imp
  Clutch Fluid Wagonpeddler_imp 32 2,581 06-14-2023, 08:09 AM
Last Post: bvictory_imp
  Clutch Not Working Henrik_imp 7 659 04-24-2023, 06:43 PM
Last Post: Henrik_imp
  Clutch pull mpuhl_imp 4 519 02-21-2023, 10:48 AM
  Clutch slave cylinder gasket Maturecheese_imp 3 399 01-27-2023, 12:33 AM
Last Post: Maturecheese_imp
  brake & clutch adjusters The Gecko_imp 10 877 11-25-2022, 08:47 AM
  Clutch Lever Full Engagement odelegacy_imp 41 2,705 10-28-2022, 09:27 PM
