Rear Wheel Bearings
(10-07-2019, 05:16 AM)Houtman_imp Wrote: replacing just one bearing in a wheel is like buying just one shoe because it i wore more than the other shoe.
Did you realize that L shoe definitely differs from R one..., I always buy a pair instead of two Tongue Big Grin
Do you mean that a L iberal shoe is different than a R epublican shoe ?
U read my mind...lol...
+ LR will talk to you soon..
Big Grin all kidding aside, and to each his own of course, but I think it's false economy to not fit two new bearings while you're at it.
Not sure how your bearing(s) failed - rare occurrence if they did. Japanese manufactured bikes run Japanese-made bearings, generally regarded better than non-OEM lower-quality bearings (China, India, or? ).
Not only are there different material quality, there are different running clearances and tolerances too. Cheap bearings may be fine for wheelbarrows or garden carts. Be sure to pack it with grease since they are skimpy any way they can be, especially if it has seals or shields on both sides - I've seen new ones that were dry inside.
If your bearings are fine, I wouldn't replace them. A new part is an untested part. Also you would likely have a hard time finding the right bearing shield/seals except from the OEM.
Rocky on post number nine of this thread I did mention that the bearing was not the problem but a misalignment on the rear wheel and chain.
(10-24-2019, 09:21 AM)jdvalero_imp Wrote: Rocky on post number nine of this thread I did mention that the bearing was not the problem but a misalignment on the rear wheel and chain.
Thanks for the alert Thumbs Up
  Front wheel bearing noise? MagnaRider 20 1,641 03-31-2026, 08:20 AM
  This is why wheel bearings are failing 1973cb750 3 323 02-05-2026, 08:11 AM
Last Post: 1973cb750
  CB11OO EX wheel rims sprint 6 611 02-26-2025, 06:16 AM
  2014 rear wheel knocking noise dunebuggy_imp 7 921 08-05-2024, 03:33 AM
Last Post: Yata-Garasu_imp
  Wheel sensors The Gecko_imp 48 3,755 07-27-2023, 03:51 AM
Last Post: The Gecko_imp
  2013 replacement wheel Randy B 8 743 11-13-2022, 10:32 AM
Last Post: Randy B
  wheel imbalance j3gq_imp 7 608 07-03-2022, 09:35 AM
  Kink in rear (spoked) wheel Ayrshire Dunx_imp 1 246 04-09-2022, 09:37 PM
  Friction front wheel j3gq_imp 12 867 12-12-2021, 01:26 PM
Last Post: jimgl3_imp
  Tires yet again - spoked wheel options Rogerdj_imp 12 934 09-05-2021, 04:56 PM
Last Post: Henrik_imp
