2014 rear wheel knocking noise
Hi everybody,
New owner (2 months) of a 2014 1100 A.
Great bike !
This morning went for a ride for about an hour. On my way back after a light, I started to hear a knocking, kinded clangy, noise around the rear wheel ONLY when accelerating, so afew clang during 1st gear and 2nd gear after all good.
At arrival I put the bike on center stand and simulate by gently applying the rear brake, same noise, hard to say precisely but it looks like every half wheel rotation.
Chain is clean and no heavy tight spot, slack is 1 1/2 inch
Wondering what happened during the ride ?
The knocking is very present only during acceleration and hard to say if it s from the rear wheel or the front sprocket
Thanks in advance
Eric
(07-30-2024, 04:51 AM)m in sc_imp Wrote: take sprocket cover off and observe as chain goes over sprocket to see if its smooth or not. (on center stand). it will be obvious if its having issues.
Sprocket teeth looks fine, smooth operation, 14mm bolt tight but it moves a bit ,very little, when I grab it. Is that normal ?
thanks
Eric
Does the chain have any "kinks". Parts of it that seem tight and didn't swivel well? I've had that happen before. Had to replace the chain. Also, you might want to check the rear wheel dampers. I've replaced mine a couple times now. Also check that the rear wheel is aligned properly.
Sent from my Pixel 6 using Tapatalk
The 14mm bolt moves? I had one come out once and punch a hole in the cover.
You said the noise appeared while accelerating, and back home you 'simulated it' with the rear brake - what does that mean (other than you heard a nice in both cases) ? What was your assumption ?
And how many miles on bike, tire, chain, etc. ?
(07-30-2024, 06:29 PM)Cormanus_imp Wrote: The 14mm bolt moves? I had one come out once and punch a hole in the cover.
No, the bolt is tight, just the sprocket, very small play,very small
(07-31-2024, 06:14 AM)The Gecko_imp Wrote: You said the noise appeared while accelerating, and back home you 'simulated it' with the rear brake - what does that mean (other than you heard a nice in both cases) ? What was your assumption ?
Put it on the center stand, in first gear apllied the brake gently and gave a bit gas.
(07-30-2024, 12:33 PM)MMC_imp Wrote: Does the chain have any "kinks". Parts of it that seem tight and didn't swivel well? I've had that happen before. Had to replace the chain. Also, you might want to check the rear wheel dampers. I've replaced mine a couple times now. Also check that the rear wheel is aligned properly.
Yes, i'm thinking the dampers, the chain has no kink that I can see or feel when I turn it free
Well,
noise is gone,
The interior of the front casing sprocket was extremely gunky, the bike has 60 000km, and it might be that some heavy packed gunk was hittting periodicly(?) the little alumimium joint between the aluminium cover and the engine.
thanks for the good replies !
I'm learning the bike slowly
(08-01-2024, 01:21 AM)m in sc_imp Wrote: .. have you checked the rear brake pad fitment? its easy to get the front part of the pad NOT in the slot and will tap on the rotor bolts. 0.02
This happened to me. Had the brake pads changed by Honda, and the front brakes started tapping/rattling on decel. Quick adjustment made it right, the tech was super embarrassed.
When I read the first post, I immediately thought "brakes?", but a kinked chain would make sense too. Lots a people don't love their chains the way you're supposed to, with a used bike it would be a prime culprit.
(08-05-2024, 02:25 AM)dunebuggy_imp Wrote: Well,
noise is gone,
Good to know... See previous comment about chain maintenance!
  Front wheel bearing noise? MagnaRider 20 1,731 03-31-2026, 08:20 AM
  This is why wheel bearings are failing 1973cb750 3 351 02-05-2026, 08:11 AM
Last Post: 1973cb750
  2014 DLX - rear ABS clunk kvdv_imp 11 917 12-14-2025, 10:29 AM
Last Post: Easynow
  Knocking noises; vibrations in the handlebar; oil sipping at valve lid gasket TheLegend 47 5,574 11-16-2025, 12:01 PM
Last Post: TheLegend
  CB11OO EX wheel rims sprint 6 649 02-26-2025, 06:16 AM
  Engine clicking/ticking metallic noise! WTF? Tortuga_imp 28 2,139 10-11-2024, 04:53 AM
  Front ABS Brake"Rain Stick" noise bflint 3 457 07-12-2024, 08:36 AM
Last Post: Race_ca1
  Rear axle diameter 2014 vs 2017 ashishNJ_imp 4 527 08-28-2023, 06:07 PM
Last Post: dopaytoplay_imp
  Wheel sensors The Gecko_imp 48 3,898 07-27-2023, 03:51 AM
Last Post: The Gecko_imp
  2013 replacement wheel Randy B 8 783 11-13-2022, 10:32 AM
Last Post: Randy B
