Rear Wheel Bearings
Hello Lads!!!
Looking for non OEM stuff (since its 90$ for OEM) but cannot find any reference on them if I google them.
How many of you have changed your rear wheel bearings and at how many miles?
Do you have a link to online supplier?
Thanka mucho!
JD
What year bike do you have? Partsfish shows the '14 bearings for less then $20 bucks each. Or am I missing something?
(10-02-2019, 11:03 PM)Lord Popgun_imp Wrote: What year bike do you have? Partsfish shows the '14 bearings for less then $20 bucks each. Or am I missing something?
Are you refering to just one bearing or all 3 plus 2 dust cap seals?
Can you send me a link please?
2014 standard
Thanka mucho!
Sent from my LM-Q710(FGN) using Tapatalk
On part fish you need parts 20 21 22 23 and 24. A bit cheaper that babbits but still comes close to 80$ with shipping added. All of those parts should be close to 20-25$ if not OEM. I think all bearings come from same manufacturers that is why i wanted to look for non-OEM
Im still on original bearingx at 48,000 miles.
(10-03-2019, 03:33 AM)The ferret_imp Wrote: Im still on original bearingx at 48,000 miles.
Awesome!
I think I have one going bad one of the ones on the sprocket side. probably my fault tightening the chain to much. Won't know until I take them apart thus why I was looking for other options other than OEM.
JD there is no gain in replacing them as a set, i replaced one on my cb919, the one on the brake side, it had water in it because it sits on an angle and when it rains it got in.
I just replaced that one, it was very obvious, when you rotate it, it felt gritty as if there was sand inside and had some play and was black and rusty inside, the water had mixed with the grease.
These roller bearings have a bit of axial movement built-in and if the bearing feels smooth it's fine, you are likely to do more harm by replacing a perfectly good bearing with another one but no harm in carefully removing the rubber side cover with a sharp pick ( practice on the old one ) to pack a bit more grease to the races, these bearings move relatively slowly for a bearing and can last 200.000 km no problem.
The bearings have a number on the side like"2604" that represent their sizes and sidecovers.
2014 standard
Thanka mucho!
2014 standard
Thanka mucho!
So there are multiple bearings in there. In the wheel and in the FLANGE SUB-ASSY. I agree that you most likely don't need to replace anything that's not bad, but do a good inspection on each bearing to determine which of them is in need of replacement.
First all I do not agree with replacing just one bearing and leaving the old ones in..."My" Belief is that all should be replaced at once even if only one failed. Even motorcycle mechanics that I have spoken with agree that if one failed maybe the other one will too shortly after...the parts are relatively cheap to do them all at once and also will give you peace of mind. That's just me.
Secondly, The problem I had did not involve the bearings(Thank God!) but it was a chain alignment issue I had. Discovered when I took both wheels to make sure everything was up to par. My screw up!
But.... Thank y'all! Love ya ! mean it!!!
Sounds good JD. We'll take the love, 'cause w'all can always use it.
replacing just one bearing in a wheel is like buying just one shoe because it i wore more than the other shoe.
  Front wheel bearing noise? MagnaRider 20 1,641 03-31-2026, 08:20 AM
  This is why wheel bearings are failing 1973cb750 3 323 02-05-2026, 08:11 AM
Last Post: 1973cb750
  CB11OO EX wheel rims sprint 6 610 02-26-2025, 06:16 AM
  2014 rear wheel knocking noise dunebuggy_imp 7 921 08-05-2024, 03:33 AM
Last Post: Yata-Garasu_imp
  Wheel sensors The Gecko_imp 48 3,755 07-27-2023, 03:51 AM
Last Post: The Gecko_imp
  2013 replacement wheel Randy B 8 743 11-13-2022, 10:32 AM
Last Post: Randy B
  wheel imbalance j3gq_imp 7 608 07-03-2022, 09:35 AM
  Kink in rear (spoked) wheel Ayrshire Dunx_imp 1 246 04-09-2022, 09:37 PM
  Friction front wheel j3gq_imp 12 867 12-12-2021, 01:26 PM
Last Post: jimgl3_imp
  Tires yet again - spoked wheel options Rogerdj_imp 12 934 09-05-2021, 04:56 PM
Last Post: Henrik_imp
