Friction front wheel
When I put my bike on a stand, and turn the front wheel with my hands, it doesn't spin freely as it should - it takes more force to spin the front than the rear wheel. Then there is a light scraping noise. There is little doubt on my part, that both come from the brakes.
Additional data points: the brake pads are not new and not at EOL, the brakes do otherwise work just fine, same pads on for at least 1000 miles.
First question : any explanation ?
Second question : is there a low effort fix ? some adjustment of sorts ?
(I really don't feel like taking everything apart Wink )
It is normal for brake pads to lightly contact the rotor.
The pads on the front are larger than the rear- and there are double of them- as well as the rotors being larger which gives them more leverage.
So you think it is just normal ?
(12-04-2021, 07:22 AM)PowerDubs_imp Wrote: It is normal for brake pads to lightly contact the rotor.
You could manually push the pads back in a little and then back out onto the disc with the brake lever a few times and then see if its any better. I've seen mechanics push sticking pads back with a screwdriver inbetween pad and disc but I wouldn't advise this.
This is just a quick fix that sometimes works, its better to strip and clean of course.
1st thing to do is take out pad retaining pins and clean them with sand paper. that one little thing can make all the difference.
Hi jimgl, that the sort of info I was hoping for, but since the designation “retaining pin” doesn’t ring a bell (while I am sure I have held in in my hands many times), ....
do you think you could find a photo, or refer to a sketch in a manual, etc. so I know what we’re talking about ?
Try this J3: https://www.partsfish.com/oemparts/a/hon...ke-caliper
Is it Item 11 (Pin, Hanger), Popgun?
Yes it is.
Hello popgun,
thanks for your help. Can you or jimgl clarify why this should work ? I assume that the pads are supposed to slide on the pins, and if they are not clean (enough) the pads may get stuck in a position too close to the disks after braking. Correct ?
  Front wheel bearing noise? MagnaRider 20 1,755 03-31-2026, 08:20 AM
  This is why wheel bearings are failing 1973cb750 3 362 02-05-2026, 08:11 AM
Last Post: 1973cb750
  CB11OO EX wheel rims sprint 6 663 02-26-2025, 06:16 AM
  Front Wheel Shimmy trouble shooting. JLEECB 5 550 12-27-2024, 02:06 AM
  Wheel sensors The Gecko_imp 48 3,964 07-27-2023, 03:51 AM
Last Post: The Gecko_imp
  2013 replacement wheel Randy B 8 784 11-13-2022, 10:32 AM
Last Post: Randy B
  wheel imbalance j3gq_imp 7 650 07-03-2022, 09:35 AM
  Kink in rear (spoked) wheel Ayrshire Dunx_imp 1 262 04-09-2022, 09:37 PM
  Tires yet again - spoked wheel options Rogerdj_imp 12 965 09-05-2021, 04:56 PM
Last Post: Henrik_imp
  Wheel weight Brad14_imp 7 585 07-25-2020, 01:56 AM
Last Post: Brad14_imp
