Checking Drive Chain Slack
Thank you. Gives me comfort that my method with a caliper is likely to be OK.
that's how I check alignment only I use a dial caliper. I too found the factory markings close enough for govt work.
TBH as long as the rear wheel is off the ground and its not in gear i can't see why method A and B should/would give different results? There can only be a finite ampunt of slack in the chain and as soon as the top run is nice and tight whatever slack there is in the bottom run can be measured. I might have a look myself........
Be interested in your research, Jfro. I'd have thought you can effectively increase the slack by stretching the chain down and measuring from that point rather than measuring from its normal resting place.
(07-01-2018, 04:46 PM)Jfro5687_imp Wrote: TBH as long as the rear wheel is off the ground and its not in gear i can't see why method A and B should/would give different results? There can only be a finite ampunt of slack in the chain and as soon as the top run is nice and tight whatever slack there is in the bottom run can be measured. I might have a look myself........
Yes, I'm now thinking the same thing, but with an additional point: From it's resting position, pushing the bottom run up OR down will make the top run tight, and show the amount of slack. However measuring the difference between up & down will show 2x the slack.
Looking at the owners manual again, and the service manual, I'll be using method B (ie. measuring just by pushing up from resting position). If you look at the diagram, I believe Honda is showing the chain resting position with bold print. Let's call this the "From" position. The diagram includes a greyed-out position above the "From" position, showing the "To" position for measuring. If Honda wanted the slack to be measured using method A, then I think we'd see a greyed-out position both above, and below, the resting position in the diagram.
Next time you visit your dealer, bring a ruler and measure the slack on a new CB.
I adjusted the slack on my 2017 EX for the first time yesterday at 300 miles. Looking at my owners manual, it did not seem ambiguous to me that method B is correct. It has been decades since I had a bike with a centerstand--it is so nice not needing to use a race stand.
Agreed.
I didn’t think of the center stand at all when I bought the bike- but I use it almost every time I park the bike.
Soooo, method B seems to be the general consensus for the correct method? I've been using method A, which would place my chain on the tight end.
(07-05-2018, 11:09 AM)dbarkdoll_imp Wrote: Soooo, method B seems to be the general consensus for the correct method? I've been using method A, which would place my chain on the tight end.
Yes, method B seems to be the consensus, and is shown a bit more clearly in the factory service manual.
I think if you used method A, and used Honda's spec of 1.0" to 1.4" of slack, then the chain would be much too tight.
  Checking valve clearances Maturecheese_imp 74 6,618 12-11-2022, 12:56 PM
  Front drive chain sprocket wear 1970Cadillac_imp 15 1,296 11-29-2022, 07:49 AM
  chain slack the Ferret 104 8,962 05-01-2021, 10:08 PM
  Chain Slack Adjustment...Am I Paranoid? Gone in 60 26 1,971 07-31-2020, 09:08 AM
Last Post: Haystack_imp
  Drive Chain upkeep LakeWylieJoe_imp 18 1,171 05-20-2020, 01:36 AM
  I have two challenges... shifting down and checking the oil level Inhouse Bob 15 1,276 02-11-2019, 01:55 PM
  Checking fuel gauge mattmcuomo@yahoo.com 2 312 06-01-2018, 02:52 AM
  Checking the oil level LongRanger_imp 27 1,715 10-18-2017, 04:13 PM
Last Post: Jeffhorn_imp
  Drive chain replacement time, probably. Rolls_imp 34 2,117 06-02-2016, 12:59 PM
Last Post: flynrider
  Checking Oil Sight Glass BackroadsRider_imp 11 849 04-12-2016, 12:58 AM
Last Post: mininsx_imp
