Drive Chain upkeep
I had to make 1/4 turn adjustment to my chain slack today (on my 2014 Standard) to bring it back into spec. This is the first adjustment I've had to make in 27,000 miles (~43,450 km). Pretty impressive. I've been cleaning and lubing every 500mi, per the schedule, with Honda Chain Cleaner & Honda Chain Lube, then wiping the excess off.
It will be interesting to see how how long it lasts from here.
Very impressive maintenance and distance driven prior your first adjustment Thumbs Up...I think, I did my first at 36000 kms, during tire set replacement.
That's extraordinary. My first chain lasted ~50,000 kms.
it is scary how clean that is in the photo
looks more like a museum piece than a ridden bike
The bike has taken me through nearly every state in the US via two lane roads. I'm fortunate to be able to keep her in a large garage.
I would like to see a video of your cleaning process. I imagine others would too.
Ferret and me particularly! ROFL
And I though I kept a clean chain... Wow.
(05-18-2020, 08:47 AM)Cormanus_imp Wrote: Ferret and me particularly! ROFL
Yea!
Mine didn't look that good new if I remember right
Here's short rundown on how it's done. It may not be the best method, but it works for me and it's fairly quick. My last VFR went 36,000mi before I had to adjust the chain tension. I'll try to get a video together the next time I do the job (500mi from now).
Items you'll need: chain cleaner, Honda chain lube (not the white lithium garbage), a piece of scrap cardboard (a section of cereal box does nicely), and a scrap piece of terry cloth. I've cut up old beach towels and gotten about 8 nicely-sized segments, or WalMart sells inexpensive terry cloth shop towels in large rolls.
Put the bike on the centerstand and lower the side stand, too, in order to create a little more working area.
With the chain cleaner aerosol can (nozzle attached), work on cleaning up the chain in segments about a foot (30cm) long on the lower run between the sprockets. I hold the rag behind the chain to catch all the overspray, then use it to wipe the grime off. Once a segment is clean, I roll the rear wheel to expose the next segment. I'm able to do the whole thing in 3-5min, because there is little grime to begin with. Even so, the rag is mostly black by the time I'm done.
Next I hit the segments , one at a time as above, with the lube (nozzle attached), using the cardboard to catch all the overspray. Once all the links are foamy, I use the remaining clean areas of the rag to wipe the excess off the side links. You can hold the rag around the chain and roll the wheel--the excess comes right off.
I suspect the lube penetrates into the working surfaces of the chain if it's hot when you apply the lube, but I may be wrong. i let the stuff sit for at least 10min or so before riding off.
I toss the rags and cardboard when done. I've had to buy maybe three or four cans of chain cleaner in 5 years and I think I'm still on the original can of lube. When on long road trips, I pack a few rags and sheets of cardboard so I can do the job when it's time.
Anyway, If anyone has any suggestions, I'm all ears.
  Front drive chain sprocket wear 1970Cadillac_imp 15 1,248 11-29-2022, 07:49 AM
  Checking Drive Chain Slack Townie_imp 26 1,801 01-15-2020, 11:14 PM
Last Post: cocojamboo_imp
  Drive chain replacement time, probably. Rolls_imp 34 2,051 06-02-2016, 12:59 PM
Last Post: flynrider
  Interesting read on Final Drive Gear ratio's CIP57_imp 10 770 03-24-2016, 03:18 AM
  Got my Drive Sprocket off Pterodactyl_imp 3 282 06-16-2015, 10:27 PM
Last Post: Pterodactyl_imp
  safe to drive 600 mile bike? linuxology_imp 9 567 01-01-2015, 12:52 PM
Last Post: Aussie_imp
