Oil level difference between check
(08-08-2019, 12:41 AM)LongRanger_imp Wrote: +1
I don't routinely check mine either. The bike neither drips nor burns oil. I simply change it according to the book and all is fine.
Plus two , never check between yearly oil change , does not leak or burn oil.
+3
Same with my CB. Oil? Never been a problem. So, why worry? Every now and then I do an oil change, not even stick to Honda's recommended interval. I lenghten it.
Wisedrum
Mitch, take the bike for a ride, come home, put it straight on the centre stand and check the oil after 4 or 5 minutes. If you can see oil, it’s good.
Danke
I generally check the oil about every second ride 'cause I like to play with the little wiper thingie.
ROFL
This topic came up before in this forum, and I am experiencing a similar issue. I follow the Honda recommended procedure for checking the oil and the results vary from time to time. When I mentioned this on an earlier post there was a variety of different responses. I checked my oil buy the book, one time, and it was low - to the bottom line on the sight glass. I drove straight to the shop to buy a quart. When I came out after purchasing the quart my oil level had returned to the normal (upper line in the sight glass) level. This is not the only time this situation has happened.
Many Thanks Dave..
I continue to experience the same problem... follow the instructions exactly and continue to get different results... my worry is that I had the bike serviced by an new and unknown dealership .... I will most likely drain all of the oil and measure it and then refill with new oil and filter with exactly 3.9 litres...
(04-19-2020, 09:48 PM)Mitch_imp Wrote: Many Thanks Dave..
I don't think, that would be a good idea. Just make sure, you measure always at the same place, e.g. in the garage. The Honda should stand up right.
Same procedure of measurment should provide similar results.
Place it up right (always the same place)
Let it idle 4 minutes
Switch off and wait 4 minutes
Look at the glass.
Photo First Check Engine Light Ever on a Bike doug1976 2 234 01-14-2026, 06:47 PM
  Check your clips! Gone in 60 3 632 07-01-2025, 11:27 AM
  CB1100 vs CB750 Exhaust Tone – What's Behind the Difference? YellowNimbus 5 1,051 05-18-2025, 07:25 AM
Last Post: YellowNimbus
  Basic Maintenance: Daily Check rdprdp01 17 1,416 03-01-2025, 02:52 AM
  Time to check the air cleaner! The A-man 6 683 08-22-2024, 09:39 AM
  fuel level sensor MBZM Rai_imp 11 948 04-11-2023, 11:38 PM
  Sound check what wrong tory_imp 3 428 03-30-2022, 12:33 AM
Last Post: 1973cb750
  Oil Level Enzofour_imp 15 1,235 05-10-2021, 09:48 PM
  Low oil level mrded_imp 33 2,303 03-30-2021, 05:51 PM
Last Post: mrded_imp
  High oil level Mixagon_imp 15 1,176 03-22-2021, 10:37 PM
