Gas leaking from overflow tubes
(08-31-2020, 11:44 AM)LongRanger_imp Wrote: Doc, yours is a better explanation than mine. Thanks for clarifying.
Not better.
We were typing at the same time but you hit the send button one minute sooner.
When I saw yours, I thought well I didn't need to post it all.
Grandson arrived from Georgia today. Do not expect to post again for some time.
Enjoyable riding to all!
After sitting 3 years, I suspect the gas has turned to varnish and gummed up the jets and their passages, and buildup is preventing the float needles from sealing. So the carbs will likely have to be removed and thoroughly cleaned.
If you're in there, I would recommend replacing the metal float needles, if they came with them, with rubber-tipped ones used on all later bikes.
  Recommendations for inner tubes? Davidjill_imp 4 591 12-21-2024, 09:03 AM
  Fork seals leaking @19,000 miles on ODO Frulk_imp 64 4,516 12-26-2023, 10:11 PM
  Oil pan leaking George050994_imp 26 1,910 08-17-2023, 09:34 PM
  Refinishing - Front Fork Tubes bflint 12 855 11-24-2020, 05:11 AM
Last Post: bflint
  Leaking fork seals Tezza_imp 33 2,074 08-04-2020, 10:34 PM
  Fuel Tank overflow drain tube. zirconxi_imp 11 851 05-29-2020, 11:36 AM
Last Post: LakeWylieJoe_imp
  Chrome Pitting on Fork Tubes dave 11 801 09-07-2018, 11:22 PM
Last Post: SportsterDoc
  need help quick - oil leaking DJS_imp 32 1,824 08-24-2016, 02:04 AM
Last Post: Riko_imp
  slowly leaking - wondering if I own a lemon CB1100 Riko_imp 10 687 06-21-2016, 03:37 AM
Last Post: Riko_imp
  Leaking Fork Seal? linuxology_imp 16 1,091 05-03-2016, 01:08 AM
Last Post: aschem_imp
