11-21-2020, 10:08 AM
At 50K miles, decided its time to clean up a few chrome and paint finishing wear stuff on my CB1100. Bought some used alum fork tubes off craigslist last night ($40) to experiment with. Looked at many how-to sites but decide to follow RestoCycle LLC approach. Steps:
1. Strip clearcoat finish with paint stripper (took 3 times to get 99% off).
2. Wash with soap/water. Dry.
3. Spray with WD-40 use Scotch Brite Hand Pads Red 7447 (320 grit) in shoe shine motion all around tube. Never slide pad down, always pickup of tube to move down tube. This took me about 30 minutes.
4. Wash with soap/water. Dry.
5. Spray with WD-40 use Scotch Brite Hand Pads Grey 7448 (800 grit) in shoe shine motion all around tube. Never slide pad down, always pickup of tube to move down tube. This took me about 30 minutes.
5. Wash with soap/water. Dry.
6. Wipe with acetone (slightly damp towel only).
7. Clamp upright. Spray w/ first coat of clear coat.
8. Per clear coat instructions, wait 30 minutes, do 2nd coat, wait 10 minutes, do final coat.
Turned out pretty good. Will use this approach to do it for real on my CB1100, but will probably use a 2x Clear Coat vs the 1x Clear Coat I used because the 2x is supposed to be better.
Products used:
Equipment used:
Fork tube before stripping:
Stripping:
Rest of pictures
Stripping continued (took 2 times/coats, plus a 3rd touchup).
Post sanding with the Scotch Brite pads:
Pre clear coat application:
Final picutures
Post clear coating (3 coats) ... next to unfinished sister fork tube.
Post clear coating ... next to my CB1100 fork tubes that I want to refinish. Pretty darn close match.
Products used:
Equipment used:
Stripping:
Rest of pictures
Final picutures
