Oil Drain Plug Washer Size
In case you need one in an emergency, you can use one off a spark plug, such as a common NGK "B" series plug. Better than using a flattened-out washer that's curling up over the lip.
(11-18-2020, 06:31 AM)pekingduck_imp Wrote: In case you need one in an emergency, you can use one off a spark plug, such as a common NGK "B" series plug. Better than using a flattened-out washer that's curling up over the lip.
good idea.
I recall a discussion on this forum a number of years ago suggesting that buying the washers via Honda car dealerships was a lot cheaper than buying the identical part from the Powersports dealers. Ferret, I think that was based on your advice.
I never had to replace a drain plug washer on any motorcycle oil sump ever in 40 years of oil changes. The plug never seized, nor did the plug ever leak. In fact, probably the worse next closest "related" experience I ever had was getting a canister oil filter off. A screwdriver through it made quick work of that issue.
good idea.
good idea.
Another optiion is to re-anneal a used copper washer.
Just let it hang from a wire, heat it with a torch unti it's red, then let it cool at ambient temperature. It will be soft again, and will crush & seal on the next tightening.
  NGK spark plug options Jonnyteabag_imp 6 592 08-05-2026, 11:35 PM
Last Post: JRD
  Booster Plug on an RS TheLegend 6 475 04-22-2026, 06:31 AM
Last Post: TheLegend
  What is this plug? MagnaRider 7 683 02-13-2025, 03:39 AM
Last Post: MagnaRider
  Spark plug socket. Jgarciajr40_imp 5 543 09-11-2023, 10:40 PM
Last Post: Jgarciajr40_imp
  What is the Correct Chain Size for a 2014 Model? chync_imp 12 1,142 02-28-2023, 01:16 AM
Last Post: Maturecheese_imp
  spark plug caps alexzanutto_imp 3 384 01-29-2023, 06:21 AM
Last Post: artashline_imp
  spark plug help, please !! The Gecko_imp 10 757 10-08-2022, 12:22 PM
  Another source for plug-in LED flasher unit. FLYTYM_imp 7 622 01-31-2022, 09:53 AM
  2013 versus 2014 wheel size Houtman_imp 19 1,556 10-08-2021, 05:11 AM
  Regina HPE chain-kit - looking forward to these coming in our size. Tev62 13 1,015 04-20-2021, 06:45 AM
