Regina HPE chain-kit - looking forward to these coming in our size.
No more chain cleaning and lubricating - soon I hope!
Pricing has been released for a chain and sprocket kit from Regina using the High Performance Endurance product, €278 incl. TAX. These were announced by BMW as a €100 uplift on a new bike purchase last year.
Not out in our size yet but I'm sure it won't be long. I will be happy to swap my chain right out for one of these when they are available. It looks like you will pay a €100 premium over a regular heavy duty O-Ring chain and sprocket set but I would be happy to pay that to keep the rear wheel clean.
Some people seem to be under the impression there is no need to adjust the chain, ever again, I don't think that is the case. They are not claiming they last massively longer than a regular O-Ring chain set either.
A world first for motorbikes with chain drive: the virtually maintenance-free motorbike drive chains from the Italian chain specialist Regina, the innovative *High Performance Endurance* (HPE) chains. And here as a complete chain set with sprocket and pinion in original equipment quality from gear professional ESJOT.
One thing is certain: probably the most annoying thing about a motorbike with chain drive is the recurring maintenance of the drive unit chain, sprocket and gear. And the rule is: it's better to clean once more and grease again. That way you'll get more out of your chain set - even if it's a pain.
It's different with the Regina *HPE* chain sets. The exceptional *HPE* chain is coated with hydrogen-free, amorphous, tetrahedral carbon (ta-C) on the surfaces of the rollers and bushings - also known as "industrial diamond". This coating reduces power loss and increases efficiency. In addition, the Regina *HPE* eliminates the need for chain cleaning and lubrication. This is not only less labour intensive, but also more environmentally friendly. But the best thing about this type of chain set is that it matches the durability of a well-maintained regular seal ring chain set.
innovative world first
chain sprocket and pinion in original equipment quality
no cleaning and lubrication
coating on rollers and bushes with ta-C
less power loss
long service life
Very interested to see how this turns out.
Interesting. The chain life is not increased? You avoid cleaning and lubrication for nearly double the cost? I'll stick with my O-ring chain and save the cost.
But what if you want to clean the chain? I can't imagine the chain would remain pristine. Would cleaning remove the coating or is there a special process/products?
Yea I wonder if you can still clean and maintain the chain and have twice the life span
It seems like a DLC coating. It won't wash out nor peel off.
(04-18-2021, 11:59 PM)Dave_imp Wrote: Interesting. The chain life is not increased? You avoid cleaning and lubrication for nearly double the cost? I'll stick with my O-ring chain and save the cost.
You avoid all the oily muck on your wheel rim, spokes and swing arm too, that would be nice to have. Unless you are doing very large annual mileage the benefit might outweigh the cost.
Convenience has a price too. The thought of not having to do the chain maintenance, as cheap and easy as it may be, every 500 miles has to be worth something right?
Convenience has a price too. The thought of not having to do the chain maintenance, as cheap and easy as it may be, every 500 miles has to be worth something right? I dont mind the maintenance when I'm home. But that would be a nice change when I go on trips.
Doing 1600 miles in a few days and trying to hit the chain in a parkinglot with the bike loaded up gets old quick lol
Yer thinkin' like a true marketer:
"What is the value of every second that you are alive?"
Not unreasonable, as long as the product is fair and stands up to its claims.
  Hum Coming From Gas Tank Area le_penseur_imp 34 2,581 09-15-2023, 08:59 PM
  What is the Correct Chain Size for a 2014 Model? chync_imp 12 1,142 02-28-2023, 01:16 AM
Last Post: Maturecheese_imp
  for those lookin for more forward foot pegs Griz53_imp 1 223 09-27-2022, 07:56 PM
  2013 versus 2014 wheel size Houtman_imp 19 1,555 10-08-2021, 05:11 AM
  Oil Drain Plug Washer Size Tev62 14 1,010 11-18-2020, 06:29 PM
Last Post: jtopiso_imp
  Sprocket Size Retsel_imp 4 380 08-14-2017, 01:30 PM
Last Post: Retsel_imp
  Handlebar Clamp Bolt size? Nappi185_imp 7 653 08-08-2017, 01:49 PM
Last Post: Nappi185_imp
  Battery bolt size Sam Mac_imp 6 503 11-11-2016, 04:49 AM
Last Post: Randy B
  Tire Size Specs? 736cc_imp 9 528 11-10-2015, 09:12 AM
Last Post: Elipten_imp
  15k Mile Look See Coming Up Motogeezer1949_imp 4 414 10-12-2015, 09:01 PM
Last Post: Motogeezer1949_imp
