Healtech eSync tool- synchronize balance throttle bodies
In theory these shouldn’t need that as they are sensors calibrated from the factory. Given they are solid state- nothing should change.
(12-04-2020, 01:52 AM)Lord Popgun_imp Wrote:
(12-03-2020, 01:55 AM)jtopiso_imp Wrote: Interesting. I worked with a guy who claimed that in his youth he tuned his alfa romeo 33 (4 carburators) with a make-shift rig made of plastic tubes and plastic bottles. Water instead of mercury, of course Smile
Regarding this tool: I don't get it: don't all 4 vaccum tubes go to a single MAP sensor? Won't pressures be equalized no matter what? I think I don't get what's really going on on the TBs and those vacuum tubes.
JT, there would actually be 4 transducers. One for each hose. The pressures would be converted to digital data sent to the attached computer for display. That's a simplified explanation.
My question is:
on the bike, there is only one MAP sensor, and the 4 vacuum tubes join together at some point, so all 4 pressures are equalized. Aren't they? So I guess, the ECU is using MAP as an average of the 4 TBs?
So I guess during testing and sync. with this tool, MAP sensor can't be used, or at least not in the same way as originally. Perhaps only connected to one of the TBs.
  Injectors syncro/balance TheLegend 15 2,092 11-10-2025, 02:07 AM
Last Post: TheLegend
  Josh’s bigger throttle bodies project PowerDubs_imp 50 4,244 10-14-2025, 05:04 PM
Last Post: jikemenkins
  Oinker Chain Lube Tool Gone in 60 4 497 01-15-2025, 08:31 PM
  Throttle cable exposed misterprofessionality 7 1,194 06-12-2024, 11:53 AM
  throttle operation The Gecko_imp 6 590 03-07-2024, 09:39 AM
  Tool Recommendations for CB1100 Yata-Garasu_imp 18 1,543 08-09-2022, 04:07 PM
Last Post: Yata-Garasu_imp
  Throttle cable replacement Stoked907_imp 1 274 05-20-2022, 09:35 AM
  Question for anyone w/ the OBD tool PowerDubs_imp 5 482 02-19-2022, 04:43 AM
  Spring Tool Houtman_imp 32 2,151 10-17-2021, 12:41 PM
  Throttle body sync? Whoops 6 543 07-10-2021, 02:22 AM
