starting issue
Oil temperature light, i just checked mine and it lights up on the startup cycle and goes out again.
This light is indicated as " warn" by Honda and is connected to the e.c.u.pin A20 and is a white/blue wire.
It lights up when a high oil temperature is measured by the e.c.u. and the oil temperature sensor is located at the back of the cylinders just below the cam chain tensioner and has two wires.
It may pay to have a look if the connector is in place and what happens if this connector ( or the wires ) is moved slightly, be careful because the terminals on this sensor ( a temperature variable resistor ) are very small, this black connector has a small locking tab that has to be pushed up by pinching your fingers to disconnect the plug.
Not sure if a high engine temperature will stop the engine but i remember riding around with it unplugged so it may only go in limp mode, worth a look.
What model and year is your bike?
Max, first post for model.
Thanks L. P.G, i missed it, i have a feeling that we may need more info about the history of the bike, i do like a challenge though so we'll dig it out at some point but so far there's no clear direction so i hope the diagram helps him to follow the trail and find the " electron strike " afflicting this bike, it seems to be happening reliably so that sounds like a good thing to have.
  Help from the hive mind: Intermittent Starter Issue (2017) JRD 10 512 01-30-2026, 02:16 PM
Last Post: JRD
  Shifting issue Cormanus 31 2,153 05-15-2024, 12:59 AM
  Arrow Slip on issue - stock gasket didn’t fit Ddawg1144_imp 4 453 02-21-2023, 07:51 AM
  Fuel reserve display issue Banksy_imp 2 276 06-29-2022, 04:37 AM
  Brake reservoir screw head issue satchit 72 5,268 04-24-2022, 11:55 PM
  Mechanical issue and hello again RickNRoll53_imp 8 676 12-16-2021, 06:46 AM
  CB 900C Custom Spark Issue goatman64_imp 3 356 11-27-2021, 07:11 AM
  2017 CB1100ex / Flat tire issue and save Senna02_imp 27 2,015 07-19-2021, 08:28 AM
  Got an issue,anybody else? FLYTYM_imp 13 988 11-28-2020, 09:51 AM
  Safety issue to watch out for. LakeWylieJoe_imp 7 503 08-22-2020, 12:05 AM
Last Post: LakeWylieJoe_imp
