Brake reservoir screw head issue
Note, screw heads on our 'bikes are NOT 'Philips' head, though they look like it.
They are the very-similar-in-appearance 'JIS' screw heads - superficially similar to Philips', but, crucially, a Philips screwdriver wil chew up a JIS screw head (unless the tip of the Philips has been ground away).
For the cost involved, it's WELL worth buying a (or a set of) JIS screwdrivers.
I did use [url=https://www.cyclegear.com/accessories/motion-pro-t-handle-bit-driver-with-jis-cross-head-bits?sku_id=1172012]JIS bits .
The other screw came out fine. I'm guessing this one is on a bit too tight. I'm letting the screws soak in some wd-40. Won't attempt removal till I have the replacement screws. I'm hoping one of the non-drilling solution works.
I should follow Juancho76's advice before I try anything too Smile
Maybe an impact driver with a JIS bit in it would get it started, provided the screw head isn't already too damaged.
Vessel actually has a JIS impact screwdriver. I have one. It’s pretty cool and would have been perfect for a situation like this.
(04-13-2022, 03:48 AM)Dave_imp Wrote: I'm surprised that nobody has suggested drilling the screw and using an Easyout.
(+1) My original thoughts too. Thumbs Up
Thank you, Lord Popgun. I looked up the Vessel JIS impact screwdriver and found one on Amazon. Anybody who wants one, here's the link:
[url=https://www.amazon.com/Vessel-NO-250001-Impact-Driver-No-250001/dp/B001WHOV64/ref=asc_df_B001WHOV64/?tag=hyprod-20&linkCode=df0&hvadid=283244379562&hvpos=&hvnetw=g&hvrand=15436171197051266056&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1013419&hvtargid=pla-441171485441&psc=1]https://www.amazon.com/Vessel-NO-250001-...5441&psc=1
Look here:
https://www.youtube.com/watch?v=_mTFQbaT3Zc
I'd use method at 5:30, but with a nail and tapping with a hammer
I have several types of 'impact drivers'... a Vesel JIS screwdriver type, a large manual one with interchangeable bits, and a 20v beast of a machine (great for car wheel nuts!).
But they frighten me... Bearing in mind that our engines are mostly alloy castings (including that brake fluid reservoir), whacking a 'screwdriver' with a hammer onto these castings seems very dangerous to me - a cracked casting seems a likely possibility.
I bought my Vesel impact JIS screwdriver to tackle the casing screws on my Yamaha. The first whack I gave it frightened the life out of me! But I'm a great big 'nervous nelly' anyway...!
I will soon be (gently!) trying the 20v impact driver on these screws, to see if I have better luck.
But 'impacting' with a hammer on some of these castings should be undertaken with great trepidation, imho.
BIG hammers can have a BIG impact on fragile castings : be very careful with them !
(04-13-2022, 09:03 PM)Houtman_imp Wrote: BIG hammers can have a BIG impact on fragile castings : be very careful with them !
Exactly! Thumbs Up
  JIS screw drivers Ridem32_imp 26 1,551 06-12-2026, 06:56 PM
  Help from the hive mind: Intermittent Starter Issue (2017) JRD 10 493 01-30-2026, 02:16 PM
Last Post: JRD
  Shifting issue Cormanus 31 2,099 05-15-2024, 12:59 AM
  Sight Glass Screw Mickey Dublin_imp 16 1,435 11-22-2023, 08:25 AM
  Arrow Slip on issue - stock gasket didn’t fit Ddawg1144_imp 4 438 02-21-2023, 07:51 AM
  Fuel reserve display issue Banksy_imp 2 271 06-29-2022, 04:37 AM
  Chrome cylinder head cap Juancho76_imp 21 1,516 04-03-2022, 08:48 AM
Last Post: Juancho76_imp
  Mechanical issue and hello again RickNRoll53_imp 8 636 12-16-2021, 06:46 AM
  CB 900C Custom Spark Issue goatman64_imp 3 349 11-27-2021, 07:11 AM
  Cams, Compression, Head Work? boynton6spd_imp 12 843 08-08-2021, 02:27 AM
Last Post: old blue_imp
