How to remove both wheels?
(04-06-2022, 09:59 PM)Tev62_imp Wrote: Centre stand and car jack on the engine bars. My IKEA step as extra insurance. I seem to remember posting this in another thread?
(+1) Yep. I don't use the stands, but keep the hoist in place nevertheless. If the hoist loses pressure, no problem: The centerstand and fork support (e.g. stool) takes care of things.
(04-07-2022, 12:50 AM)LongRanger_imp Wrote:
(04-06-2022, 11:01 AM)pekingduck_imp Wrote: I would recommend putting the bike on the centerstand, and take the rear wheel off. Then remove the front calipers and loosen the front axle bolt and axle pinch bolts, all before lifting the front end with a jack.
And reassemble in the reverse order.
+1
On my 2014, the hex nut at the end of the Honda oil filter cap wrench fit perfectly into the recess of the front axle. Once the axle bolt was removed, it was super easy to remove the axle using the cap wrench as a hand wheel to spin it out.
I tried it and it fits! That's a great tip LR!
The last time that I did my tires I put the bike on the center stand and then propped up the front with a piece of wood under the triple clamp. It worked just fine.
(04-07-2022, 04:27 PM)Randy B_imp Wrote: The last time that I did my tires I put the bike on the center stand and then propped up the front with a piece of wood under the triple clamp. It worked just fine.
Thumbs Up Try not to over-think it. Just ensure it is safely secured from a personal injury to others and the machine.
Funny, this how I do it too. Right now my car is on my jack stands!
Thumbs Up
Try an ABBA stand, can be used on any bike, bike can be positioned as you like, and it is very well made, will last forever.
I also use the centre stand and jack to take the front wheel off then support the forks with a custom wooden stand I made.
I don't like doing it but its perfectly safe if thought out properly but I'm always pleased when the front wheel is back in.
I use the center stand and a ratchet strap from the front forks to the rack for my garage door opener. Easy as can be.
  How to remove O2 sensor CB1100AZ_imp 10 879 12-13-2024, 09:57 AM
Last Post: inditx_imp
  CB1100 EX tyres & wheels Ol' RedJ_imp 14 1,136 07-19-2023, 05:04 PM
  Cast wheels 18 inch on 2017 CB1100EX with Spoke wheels supruet_imp 5 637 05-13-2023, 05:43 AM
  Laced wheels ? ashishNJ_imp 3 357 02-08-2023, 01:09 PM
  Help - Overfilled Oil, how to remove? saru2011_imp 25 1,814 08-18-2022, 08:31 AM
Last Post: ymtnpoah11_imp
  How to remove 2013 Rear ABS/Speed sensor danieljrmurray_imp 16 1,368 06-03-2022, 01:16 PM
  Replacing Wheels - Manual Instructions Ludicrous jasonsargonautalis_imp 12 1,222 12-11-2021, 08:52 AM
Last Post: jimgl3_imp
  Hit a Massive Pothole - Need New Wheels jasonsargonautalis_imp 18 1,462 12-09-2021, 01:33 AM
Last Post: Raceman_imp
  Tyres again - spoked wheels - pressures Rogerdj_imp 3 351 07-06-2021, 08:24 PM
  Anybody paint their wheels black on a '13? boynton6spd_imp 2 328 06-14-2021, 11:08 PM
Last Post: MrBob_imp
