Fuel filter replacement
[url=https://hosting.photobucket.com/images/ll29/everettmclendon/E4699CA0-FB61-4E0B-A181-EF016AE9A34E.jpeg?width=1920&height=1080&fit=bounds][Image: ec8bd72a6380ccfbc7c355786f9c11b0.jpeg?wi...fit=bounds]
[url=https://hosting.photobucket.com/images/ll29/everettmclendon/739FA58F-F95F-4D3D-BE80-F4FF84B91DBA.jpeg?width=1920&height=1080&fit=bounds][Image: c27543e17afb358d7b6c0f066a8dbc74.jpeg?wi...fit=bounds]
[url=https://hosting.photobucket.com/images/ll29/everettmclendon/59B22F12-C3D1-42BA-BB6F-4CB1E4C91448.jpeg?width=1920&height=1080&fit=bounds][Image: cd8574decfe87c1a7d5b38562574d51e.jpeg?wi...fit=bounds]
(02-04-2023, 07:47 AM)Lord Popgun_imp Wrote: [url=https://hosting.photobucket.com/images/ll29/everettmclendon/E4699CA0-FB61-4E0B-A181-EF016AE9A34E.jpeg?width=1920&height=1080&fit=bounds][Image: ec8bd72a6380ccfbc7c355786f9c11b0.jpeg?wi...fit=bounds]
Thanks for the pics.
Sent from my SAMSUNG-SM-G890A using Tapatalk
(02-04-2023, 01:55 AM)PowerDubs_imp Wrote: There is no need to ever mess with the filter.
Don't go looking for problems or your likely to make one.
hi pd, you’re mostly right, and partly wrong. If it’s not mentioned in the Honda service schedule then I don’t have to mess with it. But knowing the where, how und why still pays.
Well, in theory- you could get a service manual and read / learn how to take the whole bike apart and back together.
For anyone interested- here is one for a '13 and MUCH less than all the other sellers on Ebay-
https://www.ebay.com/itm/374450688956?ha...R8Cjr5zEYQ
95% of it applies to a 14 as well.
I'd argue that figuring out how to replace the fuel filter isn't something worth sorting out ahead of time, but it's not a bad idea to figure out how to remove the fuel tank if you have time on your hands. For one reason or another, it seems like something that always needs to happen on a bike. And on the 2017, figuring out the trick when not in the heat of battle is a decent idea since it's different than most of the YouTube and forum advice out there. In this case, once the tank is off, getting the pump assembly out is trivial.
Agree with dubs though that the filter isn't likely to need replacement ever.
It is uncommon Gecko, but not impossible to needing to service the fuel filter and pump. I am unaware of any normally maintained CB1100 model year needing the extra attention.
That said, other Honda models have not been so lucky. Example: 2019 to about 2021 Honda Africa Twin AS trim option had manufacturing debris contaminating the fuel in the tank and completely clogging the OEM fuel filter.
My dad bought a new sedan, years ago. Nice 6 cyl injected engine, and first time he goes on the interstate and at a little higher speed ... the engine simply quits in the left lane. He barely manages to pull over. What to do ? Try if it starts. No luck. Try again, no joy. Call for help, and when the truck arrives, the friendly helper asks for the keys, uses it, and ... roar ... in 2secs engine is running again. He leaves with a smile, after presenting the paperwork for the insurance.
My dad is stunned, okay he says “let’s go home”. He stays on the right lane this time, mumbling sth in his beard. And guess what happened next ?
(02-07-2023, 02:27 AM)The Gecko_imp Wrote: My dad bought a new sedan, years ago. Nice 6 cyl injected engine, and first time he goes on the interstate and at a little higher speed ... the engine simply quits in the left lane. He barely manages to pull over. What to do ? Try if it starts. No luck. Try again, no joy. Call for help, and when the truck arrives, the friendly helper asks for the keys, uses it, and ... roar ... in 2secs engine is running again. He leaves with a smile, after presenting the paperwork for the insurance.
Murphy arrived?
Was Dad able to glean from the friendly helper what the root cause was? Or it just happen to work at that moment? (i.e. Murphy went away)
Went looking for the fuel filter on Mrs.' Honda CRV, found that it is permanent and non-serviceable.
So, my CB's filter is the same, being a Honda. Right?
(02-07-2023, 03:15 AM)Gone in 60_imp Wrote: Went looking for the fuel filter on Mrs.' Honda CRV, found that it is permanent and non-serviceable.
No the CBs filter is separate from the pump, but you have to remove the pump assembly from the tank to get to it, and it's over $300 for the filter alone.
  Oil Filter dave 12 520 07-26-2026, 02:33 PM
  CB1300 headlight bucket replacement spechg 5 345 03-16-2026, 10:12 AM
  HISS Key replacement UK Davidjill_imp 12 857 01-19-2026, 05:09 AM
  Rear brake pad replacement LongRanger_imp 39 3,346 05-03-2025, 10:45 AM
Last Post: Delphisa
  New speed meter replacement ACE_IRA_imp 3 504 02-13-2025, 06:25 AM
  Pod Air Filter Traumend_imp 15 1,392 03-06-2024, 08:42 AM
  Fork Pipe replacement suggestions danieljrmurray_imp 3 462 10-09-2023, 02:31 AM
Last Post: danieljrmurray_imp
  K&N air filter fitment question nikolus_imp 28 3,352 05-20-2023, 09:26 AM
Last Post: Klamathonian_imp
  Replacement Battery dave 54 3,656 02-04-2023, 12:41 PM
  Oil filter won’t come off Jgarciajr40_imp 20 1,389 01-01-2023, 09:38 AM
