2014 CB1100 with only 5 gears
In my humble opinion, you should walk away and breathe a sigh of relief. Why pay for trouble?
Further to Popgun's post here are the instructions to check the fault codes at your own risk...
If the engine cannot be started, or to check for any stored fault codes even though the FI light is not illuminated, remove the left side cover to gain access to the service check wiring connector, which is a red connector.
The bridging wire connects between green and brown wires, see this video;
https://www.youtube.com/watch?v=iwSllBQNsWc
Ensure the ignition is switched OFF then bridge the outer terminals of the service check connector with an auxiliary piece of wire.
With the terminals connected make sure the kill switch is in the run position then turn the ignition ON and observe the FI warning light.
If there are no stored codes the FI light will come on and stay on.
If there are stored fault codes, the FI light will flash.
The fuel injection system warning light uses long ( 1.3 second ) and short ( .5 second ) flashes to give out the fault code. A long flash is used to indicate the first digit of a double digit fault code ( i.e. 10 or above ). If a single digit fault code is being displayed ( i.e. 1 to 9 ) there will be a number of short flashes equivalent to the code being displayed.
For example, two long flashes followed by five short flashes indicate the fault code number twenty five. If there is more than one fault code, there will be a gap before the other codes are revealed ( the codes will be revealed in order , starting with the lowest and ending with the highest ). Once all the code(s) have been revealed, the ECM will continuously run through the code(s) stored in its memory, revealing each one in turn with a short gap between them.
Once the fault has been identified and corrected, it will be necessary to reset the system by removing the fault code from the ECM memory. To do this, ensure the ignition is switched OFF then bridge the terminals of the service check connector as before.
Turn the ignition ON then disconnect the bridge wire from the service check connector.
When the wire is removed the FI light should come on for approximately five seconds, during which time the bridging wire must be reconnected.
The warning light should start to flash when the bridging wire is reconnected, indicating that all the fault codes have been erased. However, if the light flashes twenty times then the memory has not been erased and the procedure should be repeated.
Turn off the ignition then remove the bridging wire.
Check the operation of the warning light ( in some cases it may be necessary to repeat the erasing procedure more than once ) then replace the seat.
FAULT CODE, SYMPTOM, POSSIBLE CAUSE
1
Engine runs normally
Faulty MAP sensor or wiring
2
Faulty MAP sensor / vacuum hose
7
Engine difficult to start at low temp.
Faulty coolant temp. sensor or wiring
8
Poor throttle response
Faulty throttle position sensor or wiring
9
Faulty intake air temp. sensor or wiring
10 ( see note 1)
Engine runs poor at high altitude
Faulty atmospheric pressure sensor
11
engine operates normally
Faulty speed sensor or wiring
12
Engine does not start
Faulty no. 1 fuel injector
13
Faulty no. 2 fuel injector
14
Faulty no. 3 fuel injector
15
Faulty no. 4 fuel injector
18
Faulty cam pulse gen.r or wiring
19
Faulty ignition pulse gen. or wiring
20
Faulty EPROM in ECM
25
Faulty knock sensor or wiring
21
faulty oxygen sensor
23
Faulty oxygen sensor heat element
Good post max. Wonderin' if a post like that should go into the "self help" section of the CB1100 Forum?
GO, that is a great idea.
Ferret/Cormanus, can this happen? Would save a LOT of typing in the future.
(06-07-2022, 10:14 PM)Lord Popgun_imp Wrote: GO, that is a great idea.
Thanks Mi Lord.
To add, the post would be right next to - err correction - below the post on, "Approaches To Installing RLETs on the Honda CB1100".
I put it in the How To Forum
Please check that title is correct for what you guys want to say, and advise me if you want it to read differently
http://cb1100forum.com/forum/showthread.php?tid=18018
Max, thank you.
Ferret, might be good to amend your post to acknowledge max?
(06-08-2022, 07:51 AM)Cormanus_imp Wrote: Ferret, might be good to amend your post to acknowledge max?
good idea...done Thumbs Up
Thumbs Up
  2014 CB1100 Standard Tires Scatchman_imp 28 1,801 03-07-2026, 05:54 AM
  Buying 2014 CB1100 and have questions MagnaRider 31 2,899 09-06-2024, 05:24 AM
  Venting RE: 2014 CB1100 bvictory_imp 23 1,729 05-24-2021, 01:26 AM
  SlipOn Exhaust For 2014 CB1100 Deluxe Honda4Ed_imp 20 1,398 04-24-2021, 07:51 AM
Last Post: michael1954
  2014 CB1100 dlx price? NickLHG_imp 23 2,073 12-31-2019, 12:26 AM
  2014 CB1100 Salvage title Honda_Fan_imp 38 2,420 01-29-2019, 02:28 PM
Last Post: rboe
  2014 CB1100 Std vs 2017 CB1100 ?? ohiorider_imp 14 1,273 12-22-2018, 10:49 AM
  2014 CB1100 alternator output ohiorider_imp 7 654 10-26-2018, 09:14 PM
  2014 CB1100 standard & sundry items SportsterDoc 22 1,470 09-11-2018, 10:42 AM
  cb1100 2014 New in Box jitaylor_imp 51 3,636 06-13-2018, 01:05 PM
Last Post: Chrisvillar98_imp
