'Factory' high performance spark plugs
Ummm- these ARE OEM- Original Equipment Manufacturer - NGK
With the more modern materials and design / machining capability they have now.
It’s as if… you didn’t actually look / read at all…
i was surprised the stock plugs being efi weren't these to begin with my brother cbr600rr had oem iridium like these
When you said you tried 'these'- do you mean the iridium with the smaller tip but still standard square strap? Which would still be an improvement over the stock design- but apparently a 'middle ground'.
Or these DX from overseas with the smaller D shape and different metal?
Plugs arrived today-
[Image: 39ced0049fda235045e2076944f61ece.jpg]
Very curious to see how it goes Dubs.
Reminds me of project farms testing of different spark plug designs!
https://youtu.be/jcVF3xL_fzk
Did you ever see a noticable increase with these plugs?
Haven't installed them yet. I'm gathering a lot of different parts for all sorts of tests....and then will knock it out on the dyno over the course of a couple days.
Just arrived today set of LMAR8ADX-9S will fit tommorow
  NGK spark plug options Jonnyteabag_imp 6 641 08-05-2026, 11:35 PM
Last Post: JRD
  spark plugs after 70.000 Km DAC 16 1,569 12-23-2025, 10:15 AM
  High engine revs on start up CBX1000_imp 21 1,825 06-06-2024, 02:40 AM
  TPS Sourcing because of High Idle Obi-wan Kenobi_imp 38 2,681 09-14-2023, 10:08 PM
  Spark plug socket. Jgarciajr40_imp 5 568 09-11-2023, 10:40 PM
Last Post: Jgarciajr40_imp
  About the problem of high idling. (2014 cb1100ex) DDUMZI_imp 62 4,794 08-02-2023, 05:38 PM
Last Post: DDUMZI_imp
  spark plugs NGK LMAR8A-9S louied_imp 1 336 06-27-2023, 01:19 PM
  2017 CB1100EX Accessory Plugs TXBikerGuy 13 1,175 06-24-2023, 08:27 AM
  High mileage and oil consumption Jurlie_imp 24 2,144 04-07-2023, 06:05 AM
  spark plug caps alexzanutto_imp 3 407 01-29-2023, 06:21 AM
Last Post: artashline_imp
