Help from the hive mind: Intermittent Starter Issue (2017)
I haven't taken the time to figure this out yet (because of a combo of laziness and the fact that it hasn't done it to me again since I posted), but I was thinking about it and I don't think it is the kickstand sensor.
The bike will normally start with the kickstand down if it is in neutral.
When this happens, the start button won't work even when in neutral. Think it is likely the button assembly itself.
  Just in case anyone is interested in what the inside of our starter looks like… PowerDubs_imp 14 1,153 07-14-2024, 05:05 PM
  Shifting issue Cormanus 31 2,303 05-15-2024, 12:59 AM
  Arrow Slip on issue - stock gasket didn’t fit Ddawg1144_imp 4 466 02-21-2023, 07:51 AM
  Fuel reserve display issue Banksy_imp 2 288 06-29-2022, 04:37 AM
  Brake reservoir screw head issue satchit 72 5,341 04-24-2022, 11:55 PM
  Mechanical issue and hello again RickNRoll53_imp 8 683 12-16-2021, 06:46 AM
  CB 900C Custom Spark Issue goatman64_imp 3 370 11-27-2021, 07:11 AM
  Heat soak starter coil, or weak battery? zirconxi_imp 36 2,522 10-11-2021, 12:58 AM
  2017 CB1100ex / Flat tire issue and save Senna02_imp 27 2,110 07-19-2021, 08:28 AM
  Need a starter switch but none available Kdogg2077_imp 11 960 07-05-2021, 01:56 AM
