Just in case anyone is interested in what the inside of our starter looks like…
[Image: f278b064c0c0f0d36b39fdb60eca5679.jpg]
Went bad on you?
Yeah, what happend?
I bought a silver starter but decided I can do better.
So I’m going to strip and polish the front and center sections of my black one instead. Still going to keep the back section black as that lines up perfect with the polished side cover.
[Image: 09e7b41fabcb41bd5d7da779adba4f94.jpg]
[Image: 3783ea4e5c94c3436ae8641a65bc1800.jpg]
Thanks PD. When you removed the starter, does the case need to be removed so that the drive gear on the starter motor shaft can be properly realigned during reassembly?
Nah... there is enough rotational room before bolting down.. easy peasy.
Jeebus, M, that is catastrophic starter failure right there.
I'm interested in the starter polishing project and look forward to updates. I'm trying to picture how it's going to look.
The worst starter incident happened to myself due to distraction by too many other things. My old departed work van was stuck in a parking lot at Fontana Speedway. At the time, I was fixing things as fast as they came up. I knew it had a dodgy gear position indicator, so I wired up a bypass, still nothing. Also bypassed the neutral safety switch. By the time my phone was down to 20% battery after watching YouTube videos about doing both, it was getting too hot to keep working on it. Used the last of my battery to call for a tow, and on the long way back to the shop, thought about the one thing I didn't try... as soon as the tow truck dropped the van, I thumped the starter with a hammer. Of course, it started right up.
Geez Mark!!
Water intrusion?
Also wondering why the Phillips around the housing?
(06-19-2024, 07:23 AM)Gone in 60_imp Wrote: Jeebus, M, that is catastrophic starter failure right there.
Good enough… now to clear-coat, reassemble, install.
[Image: 411118a813d00ccefff341d9a5d82869.jpg]
[Image: 7b24b29a79ddb17c60a328d5958cfdb8.jpg]
[Image: 572776ab9dec3d13527ec54b34bc808c.jpg]
[Image: 4326398df24c8072c26e865a694c9776.jpg]
Huh. That's pretty cool.
  Help from the hive mind: Intermittent Starter Issue (2017) JRD 10 578 01-30-2026, 02:16 PM
Last Post: JRD
  Heat soak starter coil, or weak battery? zirconxi_imp 36 2,605 10-11-2021, 12:58 AM
  Honda OEM Top Case wrong OEM rack iamlegend21087_imp 1 292 07-28-2021, 11:23 AM
Last Post: Rox_imp
  Need a starter switch but none available Kdogg2077_imp 11 995 07-05-2021, 01:56 AM
  What is inside a fuse box? mrded_imp 4 357 05-16-2021, 10:55 PM
Last Post: 17-CB-002
  Clean engine cutoff, starter buttons mustang462002_imp 3 403 03-19-2021, 04:13 AM
Last Post: whizzle_dizzler_imp
  Weak Crank Case Bolts? bertypower_imp 19 1,582 09-12-2020, 10:22 AM
Last Post: bertypower_imp
  Help, need assistance in assembling a key tumbler for a Top case 17-CB-002 6 495 07-11-2017, 01:16 PM
  In case you're curious, exhaust material kDiqq_imp 12 747 10-31-2014, 09:39 AM
Last Post: Insolentsquid_imp
  CASE GUARDS KOWALCH1_imp 2 298 07-02-2014, 05:48 AM
Last Post: The Spaceman_imp
