Dyno Results Today
Threads: 698
Likes Given: 792
RE: Dyno Results Today
I have 2 Q's..on the second dyno chart why the two lines same color, with the darker set having more torque and HP? and did yours rev all the way to 8500 as it appears on the dyno?
ok I thought of a third Q.. were you there watching and did they run it in one gear or multiple gears?
12-18-2013, 01:58 AM
12cb96vfr_imp Offline
Threads: 27
Yeah i should have clarified; base run was before the tune, but after the bolt-ons. I don't have a bone stock dyno pull unfortunately
Yea we pulled it in 2nd thru 5th actually. Yup all the way to 8500 in 3rd.
We did a run right of the bat to get the baseline numbers; then tuned it for like 2 hours & then did the final run.
My main concern was getting the air:fuel dialed in, hp and torque numbers were cool for reference..
He did say the base map on the PCV was very close... so if you have a slip on but no time for a dyno run it'll still run pretty good
12-18-2013, 04:16 AM
flynrider Offline
Phoenix, AZ
Threads: 28
Likes Received: 6 in 2 posts
(12-18-2013, 12:42 AM)12cb96vfr_imp Wrote: Yeah I'm happy overall - I tell ya the way it runs now is great - it is so smooth!
The cool thing is he said movin forward any other mods I do tuning it should be a snap. This time we had to block off the o2 sensor and create a place for the "sniffer" to get the reading before the catalytic converter. That was what took the most time. Now that that part is done, the rest is cake.
like the moron I am i took the picture of the dyno chart at 8meg, so the file is massive, and I can't find the printout he gave me to take another pic (hope it didn't fly out going down the highway LOL).
Im also uploading my map soon - waiting for my wife to wake up before I go rummaging around looking for the disc hahaha
here is a stock CB for reference
ALMOST FORGOT - you have to run it in 3rd gear to get to the redline - very important.
The speed limiter kicks in right before the rev limiter in 3rd so you can get the best run - power actually drops off just before (and I mean just before, like 7999 haha) 8k RPM - and if you're in 4th it'll kick in around 7k.
We looked at some options to remove the speed sensor but since its tied into the speedo I didn't want to mess with anything. If you cut it you're going to put the bike in safe mode and limit RPMs in every gear.
Kinda hoping someone will come up with a way to override it, but I never ride above the posted speed limit personally Smile
chart attached
Interesting. Ideally, a dyno roll on run is made in whatever gear is closest to a 1:1 ratio. That eliminates hp losses due to the gear reduction in the transmission. For the CB11, 5th gear is almost 1:1. Third gear is 1.545:1, so I'd expect actual power at the rear wheel in 5th to be a bit higher than your chart.
Of course with the speed limiter, it's kind of a moot point.
12-18-2013, 09:40 AM
Threads: 27
chart attached
Cool, I didn't know that! I was primarily worried about the a:f as opposed to the numbers, but man that speed limiter sucks. When you can't even get thru 3rd gear without it kicking in, thats just too intrusive
12-18-2013, 10:25 AM
Romo1969_imp Offline
Threads: 17
(12-17-2013, 12:23 PM)12cb96vfr_imp Wrote: 88hp, 67ftlbs
2-bros slip on, k&n, PCV
Trying to upload the screenshot but the file is too large - i'm trying to crop it now - the torque curve is awesome.
Bike is SILKY SMOOTH now, that is the best part.
What is PCV?
02-15-2014, 12:34 PM
SanPete_imp Offline
Threads: 7
Re: RE: Dyno Results Today
What is PCV?
What is PCV?
It could mean many things but in this case POWER COMMANDER V. You can Google it for CB1100 for prices, specs, and video installation.
Sent from my SM-T217S using Tapatalk
02-15-2014, 01:39 PM
  Went back to the dyno today... PowerDubs_imp 20 1,513 11-12-2020, 12:09 AM
  Power Commander 5 and Dyno Tune iamheero_imp 7 592 07-18-2020, 04:14 AM
  ECU from Guhls/Dyno ready HikerToo_imp 120 10,273 04-16-2020, 07:53 AM
  Dyno results....Re-dyno after reflash? Waldo_imp 36 2,713 01-22-2018, 04:51 AM
  Best Dyno HP numbers? Kawiboy_imp 33 2,510 10-27-2016, 03:22 PM
Last Post: Ulvetanna_imp
  DYNO run today rusty1_imp 3 356 09-27-2016, 11:06 AM
Last Post: Jteakus_imp
  I need Dyno maps CIP57_imp 13 915 04-30-2014, 07:48 PM
Last Post: cade_f_imp
  Wanted to share my map from my Dyno 12cb96vfr_imp 12 696 12-31-2013, 05:41 AM
Last Post: 12cb96vfr_imp
