Wheel exchange
Gravity Storm_imp
New to the forum
New to the site, so I am not going to ask an oil question. I have just purchased a 2017 and I am not a fan of spoked wheels/tube type tires.
Does anyone know if the cast wheels of previous years can be fitted with out much trouble?
Thanks for any help.
Gravity Storm
My guess is they are a direct swap. You probably won't have much trouble finding someone on here (maybe even local to you) to exchange with.
The '13's rear axle is larger than the '14s and up. Part numbers were the same for the 13 and 14 front axles when I looked a few weeks ago.
So try to find someone with a 14 to swap with. And maybe check a parts diagram to be sure.
Oh, yeah, Welcome from Va. Beach!
Didn't Honda reduce the rear axle diameter on the 2014 models? If so a 2013 rear wheel might not be a direct swap.
You read my mind popgun.... strong with the force you are!
Yes, BestStandard
I too would prefer tubeless wheels but besides the wheels itself you also have to think about the brake set up.
Have been looking for mag wheels for the 2017 in Japan but so far no luck.
I'd be seriously interested in trading my '14 DLX cast wheels for your EX wire wheels, but only if it's a proven DIY swap. I'm not interested in being a guinea pig and discovering they won't work or will require motorcycle surgery or modifications.
I can't remember whether it's the EX or the RS, but one's rear hub is a completely different shape to the 13 and before.
Oh, and welcome Gravity Storm.
To go from spoke to alloys is NOT a direct swap in that all the parts are not common..
The brake rotors are not interchangeable. Neither are the abs rings, nor the wheel spacers, and the rear brake caliper brackets are also different.
Jim21680_imp said:
Don't let this question hijack the thread...but why did Honda reduce the axle size on the 14's?
Jim, In one of the design engineer discussions that Honda posted he said it was done as it would flex more and give a better ride.
Link to article: Honda Motor Co.,Ltd.|Honda Global Corporate Website
And the quote: Korogi:
Take, for example, the rear axle. By reducing its diameter, the axle-shaft rigidity is reduced. The aim is to create a cushy feel, and increase the sense of security. By tapering the collar in the edge of the axle-shaft, we created a 'delay' or 'buffer' in the movement.
I think this delay, 'gentle,' or 'dull,' is what gives depth to the CB1100's character, and its an aspect we had a lot of trouble in perfecting.
My question would be, how much does an axle flex?
If you had two bikes side by side, it is just a matter of figuring out how much to swap. The bikes have identical frames. If you swapped swing arms and everything attached it would likely be a direct swap. That would be a lot of work though.
i dont understand....you buy a new bike but not direct the RS ? or, why you dont ask the honda dealer as first befor you make the first ride ?
better now costs and troubels ?
Alp, we don't get the RS in the USA :(
Gravity Storm
Gravity Storm,
If you care to share...I was wondering why you would buy a 2017 and want to exchange the wires wheels when you could get a 2014 with the mags for a lower price? I know price isn't the only thing and that the 2017 is the new shiny penny but wanted to get your thoughts on how you bypassed the 2014 that has the wheels you seek. Thanks!
