Dave,
"AS" forget about this...it should be written ..."as" far as to PCSV....
1* test condition:: on center stand, engine hot/normal operating temp and NORMAL RPM (1050)..if for any reason is not within specs, wait until it stabilizes within..
2* disconnect THICK/YELLOW vacuum hose end **that goes from PCSV to Th. body/intake manifold = this will create vacuum leak or as if PCSV were stuck in open position (normally closed) and register RPM change....it may very, so watch it for a while..
** careful, not to break nipple to PCSV
Unplugging the electrical connection will not be the same thing as removing the hoses (Popgun is perfectly correct)
YELLOW SKINNY HOSES DISCONNECTION...might be more difficult to achieve , since there is less access to inner throttles ??? have a look..
Max is recommending that I disconnect the two EVAP ( skinny vacuum hoses/yellow & blue, linking each th. body, Honda calls'em MAP vacuum hoses) system hoses (hoses identified with yellow marks in previous post), and I assume that this is the same thing as the PCSV?(..generally, all seems to go to intake manifold) . This seems like a pretty simple test that I can do. If my bike is running fine (1,050 RPM, warm idle) and I pull off these hoses what should I expect = YOU SHOULD SEE RPM CHANGE...watch for a while what is happening with RPM...may go up, down...
Let us know, please... before next step as per Max/SportsterDoc/Popgun
pb
