I installed a G2 Throttle Tamer, here's how I did it...
Remove bar end, hand grip and switch housing screws.
Because the throttle cable length prevents you from simply sliding the throttle tube straight off,
you will need to remove the bars in order to remove/install the throttle tube.
Simply slip the OEM throttle tube out of the switch housing and remove the cables.
The G2 Throttle Tamer cam is larger than the OEM.
Getting the larger G2 Throttle Tamer cam to slide back into the switch housing is a little tricky without loosening the cable adjustment at the throttle body,
but it can be done with a little manipulating, but its tight.
Reinstall throttle tube, switch housing screws, hand grip and bar end... go for a test ride.
TINK
To: "'Brian \"TINK\" Tinkler'" <tinkler@xxxxxx.com>
Subject: RE: Honda 2014 CB1100 G2 Street Tamer?
Date: Oct 13, 2014 7:16 AM
Yes, it just isn't listed. Sorry about that!
Here is the link and model to order (same as ST1300):
http://www.g2ergo.com/store/g2-street-ta...ttle-tube/
Thanks!!
Gary
-----Original Message-----
From: Brian TINK Tinkler [mailto:tinkler@xxxxxxx.com]
Sent: Saturday, October 11, 2014 7:58 PM
To: street.tech@g2ergo.com
Subject: Honda 2014 CB1100 G2 Street Tamer?
Can you tell me if there is G2 Street Tamer for the 2014 Honda CB1100. please, thanks.
Brian "TINK" Tinkler
TINK
Thanks!!
Gary
