Chucky_imp
First service completed
I was attempting a modification to the throttle cable tube/guide up by the throttle. As a result of a handlebar/mirror modification I needed to improve the bend/radius of the tube to allow the throttle to move freely when the handlebars were turned past 2/3 to the right. The bike is a 2014 standard and there may be small differences with the throttle cables...? While trying to bend the upper tube slightly to alleviate the radius I broke off the long adjustment nut next to the small lock nut. It was a stupid mistake.
It looks like I'll need to replace the entire cable. The Honda cable(s) will work fine IF I can get the tube(s) with less of a bend. Is there an aftermarket option where I can specify that radius for a custom application? I know it would be easier to go back to stock bars and stock cables, but the new riding position is much better for my height. The factory bars had me in a position for my butt going numb quickly. I used the Honda CB500F bars and really like them. I want to stay committed to the new riding position as it is comfortable for me. Besides, the damage is done now and I want to move forward. Thanks for any input.
I was thinking of ordering the cables for a 2013. I will need to find out if the lengths are the same as a 2014 model. The key to them working would be if the bend of the throttle tubes was less than the 2014 models. If they turn out to be the same part it won't matter and I can use a small tubing bender to adjust prior to install. Custom throttle cables would be the alternative.
