Rust and Corrosion
WK57ABF_imp
Took my white tank & silver side covers in for respray and the rust under the tank near the two forward location points surprised me. I was aware of rust around the filler neck on the tank and had it under control, also the rust on the steel fork brace and the oil cooler lines.
The aftermarket grab handle has rust on the welds also the rear view mirrors are both rusting and are covered in ACF50.
Fin rot on the engine continues to creep and is now appearing on the left hand side of the cylinder barrels. And, now I see rust on both ABS discs.
The bike was stored in a heated garage last winter and my wife wax polishes it twice a year.
It seems a rat bike is evolving before my very eyes with no help from me.
Still wouldn't part with her.
John in the UK
I've recently found rust on the triple clamps, fork tubes and front turn signal bases. The rusted turn signal bases were treated with a solution that stopped the rust and formed a paintable surface. Other rust areas were cleaned up and treated with some AC50. Rust is a weakness with some CB's I believe. BTW, my bike stays garaged and has rarely been ridden in rain.
I'm picking up spots of surface rust as well. It's the curse of having no garage, I suppose. The wife feels like building a $25k garage for my $6k bike might be too much. Harrumph.
However, I am thinking about a smaller shed for just the bike. It'll need some heat and a fan to keep it dry, though. Gotta think on this...
Well it can't just be Honda's work if the aftermarket stuff is rusting too, although I must say some CB's are certainly rusting more than they should. Never seen anything like that spotted cylinder/head though. I have seen some CB's where the paint on the fins is chipping off.
That's a shame WK
My CB tends to show sort of the same cosmetic mutation as your bike does right from the start. But not that hard and in a way shocking. Honda did something wrong with the first series.
All I do is to paint some heat resistant silver car paint on the concerned motor parts
and take care of them with a ballistol oil wipe very often. The optical mutation is going to stop somehow, but I always be aware. Otherwise the ugliness will go on....
But it's only an optical problem, the machine runs well.:celebrate:
Wisedrum
There was discussion once, either here or on the UK board, that a batch of engines didn't get prepped properly before painting. I don't know if that is true or not as there was, not supprisingly, no official word from Honda.
Why should Honda admitted this so called fact?
Some German users tried a regress within the guarantee.
All I remember was an result open and long process of getting a beautiful again.
I don't care about it that much and take care of the Honda by myself.
There are ways to keep the CB looking good with a certain amount of work.
Or as some other drivers did, they sold the CB because of these faults....
I don't have this in mind. There are bigger problems in the world than
not well painted engines and other parts.
Wisedrum
Some small spots of paint have come off my cylinders outside fins. It's a black '14, under 3k mi, garage kept and I've had it in the wet maybe three times ever. I'm not happy about it, but some flat black "gun kote" blended in perfectly. Like it never happened. Oh well.
I've stripped the bike down a fair bit to do a few mods and a bit of maint and the front of the engine is in a rotten state. I'll post a few pics tomorrow but it's covered in white fur, alloy corrosion and the silver paint has fallen of a fair percentage of the front of the engine.
I do keep it out side and do run it all year round but i treat it with ACF50 and give it prince when i get home after most runs in winter. Bit poor I'd say. I may take it up with the dealer before the warranty is up. I did have the spark plug manifolds replaces under warranty last year as the paint had fallen off them.
Typo - Prince + Rinse....
Shinchan_imp said:
You're supposed to ride your bike down *to* the ocean, not *in* the ocean...
he's from Britain, wich is surrounded by the sea and ocean....so he's basically f*cked and there is nothing you can do about the place you live your life...
that said, Honda has some serious paint issues if they are that sensitive...I feel for you WK57ABF :-/
I blow dry my bikes with a Blaster bike dryer after washing them. Water and associated caustic minerals have to sit and dry on the surface for rust to get started.
It appears he lives near the sea or around industry that most likely causes acid rain or some kind of mineral laden rain. I'd wash my bike every week and blow it dry. You can't really wax your engine, but I'd wax everything thing I could every three months.
It really is a terrible shame about the bike but you can't control the environment you ride in. I'd certainly keep it in a garage. Keeping it clean and dry is about all you can do.
Thanks to all who have contributed to my rust thread.
I am convinced that the cosmetic issues I'm experiencing are not down to my lack of care and maintenance, rain, salt, my island environment, etc. but is a manufacturing defect.
I am out of warranty so it's my problem. Will just have to try Krupator's solution of gun-kote. I see it's made in matt silver so will give it a go. Could someone recommend the correct grade - 2400 seems to be the one but I am not sure.
Beardy from London had corroded parts replaced under warranty and another UK rider had corroded cylinder barrels replaced by Honda under warranty but it's too late for me.
John in the UK
I'm in Holland at the moment and my buddy has just imported this wagon from Chicago, Illinois, 44 years old, original paint, sound chassis and comes from the rust belt.
Wish my bike was made by Chrysler!!!
John in the UK
WK57ABF, I'll find out what I put on mine as soon as I can and post it. A friend of mine had some in his garage and recommended I use it to touch up my motor. It's holding up well so far!
I didn't realize there were so many different offerings of the stuff. The stuff bakes on and cures so I put it on immediately after a ride as the motor was hot. It sure does stink when you put it on.
John in the UK
John in the UK
John, I grew up near Chicago and have owned a few similar cars. That one didn't spend it's life near Chicago. It was likely in the west or south regions of the USA during the part of its life where it was used everyday then moved to Chicago when it became collectable. Then it was garaged over the winter to protect it.
My first car after graduating high school in 1994 was a 1972 Plymouth Gran Fury, the trunk (boot floor), rockers, floorboards, rear quarter panels, and more had large holes and I thought it was one of the nicer cars I had seen in the area.
