jasonsargonautalis_imp
First service completed
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
jasonsargonautalis_imp said:
Thanks for the tip.DBM_imp said:When replacing bearings heat the cases/hubs and use a long skinny punch and slowly work it out. Put the new bearings in the freezer and then reheat the pocket. They will drop right in.
For the rear wheel on page 13-12:
Quote:Rear pulser ring bolts (3)
Rear brake disc bolts (5)
Right dust seal (1)
Right wheel bearing (1)
Left wheel bearings (2)
O Ring (1)
This seems wildly overzealous to me on Honda's part but I don't claim to be a mechanic. I know some parts undergo deformation as a part of proper seating but the torque values on this are rather low (the driven flange bolts, which I'm not uninstalling, being the highest in the 108 N.m/80lb range). I've mostly owned older bikes with manuals that don't call for much part replacement outside of gaskets - so I don't know what to think.
I want to remain safe but I need a realistic assessment on what I actually need to replace. I don't have the money for all of this right now and I'm going to need the bike to get to work soon. Can anyone with experience in this give me some guidance?
Ugh that's a massive pain. So yeah these are the bent up wheels that are going out to be re-shaped. The person I'm talking to has asked for the rotors to be uninstalled for reshaping. The bearings feel fine on the bike but I'll have a better idea once the wheel is uninstalled. If I get them off, and the bearings are trashed, I might just buy Houtman's wheels. I suspected the rotor bolts would need replacement but the rest of it is a surprise.Lord Popgun_imp said:First, are you building a bare wheel? Or re-installing one with the rotors, bearings, etc installed?
If reinstalling parts, you could use the old bearings if necessary, but the disk bolts should be new ones. Reinstalling the old ones have been known to sheer off when re-torquing them. Then fun starts.
And—
The disk spring washers, springs and collars should be replaced also so as to ensure the disk floats properly.
Failure to do so could lead to brake binding as a member found out.
The caliper bolts are ALOC bolts. That means the bolt comes with a locking compound on it and are one-time use. OR, put your own thread locker on it and torque to spec. That is what I do based on my dealer saying they do that.
If you are installing bearing, read the instructions a bunch of times. You can’t just bang them in and be done. They have to be seated correctly and not bind the spacer tube in there. Someone else may chime in on this as I haven’t done this job yet.
This is what my assumption is on a lot of their replacement suggestions. I've talked to Honda techs in the past that say they don't replace a lot of parts Honda says to put as new because it's overkill. (e.g. You're supposed to replace the gasket for the fuel line every time you disconnect it, apparently.)GoldOxide_imp said:Honda is probably compelled to be very conservative and specify a lot of part replacement, assuming nothing about the condition of the used parts and the issues remarked by Popgun. This may help keep their corporate lawyers idle.
So this is what I initially thought based on the graphic on 12-18 [uploaded a scan here]. However the graphic on page 12-19 [[url=https://i.imgur.com/CNk44rw.jpg]scan here] implies that the bolt, spring, collar, and washer all need to be replaced by putting the [NEW] symbol by "[2]/[4]/[5]/[6]". Do you think this is just a lack of clarity on Honda's part?pekingduck_imp said:GO, the phrase "an abundance of caution" comes to mind. And as Popgun says, it depends what you're doing. If you are powdercoating the wheels, it's not a bad idea to replace the bearings and seals but, again, not mandatory.
New caliper and rotor bolts come with a "locking" adhesive, but could be re-used with a proper amount of locking adhesive. But lacking the proper type adhesive, someone might use silicone sealant, super-glue, anti-sieze compound, or nothing at all.
Not using the correct locking agent impacts the torque reading, at the least. So bolt replacement is the idiot-proof solution.
According to the manual, the washer, spring, and collar for the discs do not have to be replaced.
jasonsargonautalis_imp said:Ugh that's a massive pain. So yeah these are the bent up wheels that are going out to be re-shaped. The person I'm talking to has asked for the rotors to be uninstalled for reshaping. The bearings feel fine on the bike but I'll have a better idea once the wheel is uninstalled. If I get them off, and the bearings are trashed, I might just buy Houtman's wheels. I suspected the rotor bolts would need replacement but the rest of it is a surprise.Lord Popgun_imp said:First, are you building a bare wheel? Or re-installing one with the rotors, bearings, etc installed?
And—
The bolt collars in particular are shockingly expensive ($10.50/ea?!). Is there a better place to look for parts than Partzilla?
I'm comfortable putting threadlocker on the caliper bolts. I have blue for sure and I don't mind buying red, if need be.
I have half a mind to track down one of those Honda certified techs I used to know and ask.
And—
Seems like that's the side they want to err on, yeah.GoldOxide_imp said:This is what my assumption is on a lot of their replacement suggestions. I've talked to Honda techs in the past that say they don't replace a lot of parts Honda says to put as new because it's overkill. (e.g. You're supposed to replace the gasket for the fuel line every time you disconnect it, apparently.)jasonsargonautalis_imp said:Ugh that's a massive pain. So yeah these are the bent up wheels that are going out to be re-shaped. The person I'm talking to has asked for the rotors to be uninstalled for reshaping. The bearings feel fine on the bike but I'll have a better idea once the wheel is uninstalled. If I get them off, and the bearings are trashed, I might just buy Houtman's wheels. I suspected the rotor bolts would need replacement but the rest of it is a surprise.Lord Popgun_imp said:First, are you building a bare wheel? Or re-installing one with the rotors, bearings, etc installed?
And—
So this is what I initially thought based on the graphic on 12-18 [[url=https://i.imgur.com/AZ3xUcn.jpg]uploaded a scan here]. However the graphic on page 12-19 [[url=https://i.imgur.com/CNk44rw.jpg]scan here] implies that the bolt, spring, collar, and washer all need to be replaced by putting the [NEW] symbol by "[2]/[4]/[5]/[6]". Do you think this is just a lack of clarity on Honda's part?pekingduck_imp said:GO, the phrase "an abundance of caution" comes to mind. And as Popgun says, it depends what you're doing. If you are powdercoating the wheels, it's not a bad idea to replace the bearings and seals but, again, not mandatory.
I reckon if the bike is out-of-warranty, then the "excessive" precautions are moot.
[/QUOTE]pekingduck_imp said:GO, the phrase "an abundance of caution" comes to mind. And as Popgun says, it depends what you're doing. If you are powdercoating the wheels, it's not a bad idea to replace the bearings and seals but, again, not mandatory.
So this is what I initially thought based on the graphic on 12-18 [uploaded a scan here]. However the graphic on page 12-19 [[url=https://i.imgur.com/CNk44rw.jpg]scan here] implies that the bolt, spring, collar, and washer all need to be replaced by putting the [NEW] symbol by "[2]/[4]/[5]/[6]". Do you think this is just a lack of clarity on Honda's part?pekingduck_imp said:pekingduck_imp said:GO, the phrase "an abundance of caution" comes to mind. And as Popgun says, it depends what you're doing. If you are powdercoating the wheels, it's not a bad idea to replace the bearings and seals but, again, not mandatory.
