Mixagon_imp
Sorry I know this has been discussed before and I've searched and read all I can find.
Ok here's my problem, I am now sometimes carrying a pillion which makes me sit further forward (which has solved the needing bar risers problem) but now the brake pedal is to high
I've read that there is half an inch adjustment but not on mine it seems. So on the adjuster rod I have a 14mm nut and two 12mm nuts which I assumed would lower the brake pedal but on screwing both directions to the full the brake pedal remains the same 32cm off the floor. All that changes is when the brake light comes on or not.
It was only a quick try as time was short but anyone know how to lower the pedal or what I did wrong.
