Ulvetanna_imp
Road warrior
I installed a Galfer 3-line kit on my '13 Standard and gave it a good hard test ride today. Had to clean the pads with good, acetone-base brake cleaner but once everything settled down, braking was improved immensely, so much so that I would put these binders on a par with my '15 ZX-10R or '12 GSX-R 750. So much better, the control is greatly improved and much easier to modulate to get the precise amount of braking into bends.
I've got the double-line setup on a couple of bikes and that's not bad either; I understand the triple-line is best, having the least amount of brake line and being very easy to bleed. I also have a 3-line "GP" brake line setup on my Ninja, but the master cylinder is just a touch mushier than the CB1100.
They made it 3" shorter to fit the CB500 bar setup, worked out very well.
Also did the clutch line and it feels much better, but have not actually ridden the bike with the clutch line replaced yet.
You gotta remove and replace the tank for that little operation so it's a couple of hours at least.
Sincerely, I would NOT recommend these lines for most riders because the braking action is unexpectedly powerful and I have read more than one thread about riders locking the front wheel, etcetera.
Obviously if you have ABS...well, I'd probably just leave it alone in that case, too much plumbing!
But for the sportier style riders, these brakes are fantastic. And I still have the stock OEM pads, with over 10K miles on them. I like the EBC HH Sintered, but won't be installing them as the brakes are terrific now.
