Oil Horror Story
linuxology_imp
Got my front tire changed by the dealer and got my bike out the shop. Decide to go for a ride and about 5 miles into the ride I look in the mirrors and plooms of smoke. I attempt to slow down and it seems my rear brake is not responsive. I think at the time that the smoke is due to brake fluid on the exhaust so I turn it around and decide to head for home. I go for a mile or two and look at the gauges to see the oil light flickering. I decide that I am going to make it the rest of the way without pulling over as the bike is still running well. Oil light is still flickering. I make it to my destination and turn off the bike. I pop the seat and look to see the reservoir fill is below the lower level. I then look to see the oil and there is nothing showing on the indicator. Left it for a few hours. Pull the filter to find another gasket under the filter (doh!!). I put about 3 quarts in until oil showed in the window indicator. The rear brake reservoir fill looks good now. Maybe oil was on the rear disc and that's why the brakes didn't feel right. Not sure. Really thought it was brake fluid issue for a long time. Guess I was in crisis mode. Do you think the engine could be damaged? It never showed signs of engine(i.e. knocking) on the ride home.
Who changed the oil? When? Was this the first time the bike was ridden since the last oil change? Was there oil all over the bike, tire, rear brakes?
Doubt that there was any damage but you were down to just over a quart in the bike. That's not much but IMO probably just enough to keep from doing any damage since oil sticks to metal parts for awhile.
Holy cow though, glad you noticed it.
it was my fault, i changed it. 2nd time it was ridden, but first time for more than a couple miles. yes oil all over! i'm sick. I will do a good cleaning tomorrow.
There seems to be 2 things going on here. First, it appears your engine oil leaked out and that got on the exhaust and caused the smoke. AND it got on the rear rotor/pads and messed up the braking. It if got on the rotor, it got on the pads and you need new ones. NOW.
The brake fluid level going up and down is a concern as the brake system is a sealed system and the level should be pretty constant. Of course it will lower as the pads wear. I'd say at the very least the rear needs bleeding. I'd just flush it all out with new when you change the pads.
That oil light flickering was telling you that you had low oil pressure. It flickers because the oil pump was not getting a steady supply of oil and thus the pressure was coming and going.
In another thread I mentioned that if the oil light comes on, you should IMMEDIATELY shut off the engine. Catastrophic damage and or engine seizure can result from lack of oil/pressure. Sometimes quickly! But like Ferret said, most likely you are good in this case.
When oil leaks out like that it can also get on the rear tire. Make sure you clean it all off. Oil on tires is a bad thing. The tire can easily lose grip and dump you. You don't want that! :)
I might add that I was just guessing that there won't be any damage. I assume that due to the fact that the engine never misfired or quit and there were no strange noises that you heard.
I'd guess that since he was getting sporadic pressure there isn't any top end damage or real wear. And we know it didn't spin a bearing or we be getting asked what the bad knocking noise in the bottom end is. :)
I mean really, all he can do is put new oil in and ride it. If it was a race bike he could sit on the couch and watch TV while the crew pulled the engine apart. :). The brakes though. That's worrisome.
This cannot be stressed too much. The typical oil pressure idiot light (as opposed to a gauge) won't alert you until the oil pressure is very close to zero. Continuing to ride with the light on is very risky to the engine's health. In addition to pressurized oil feeding the top end, our engines also depend on a quantity of oil in the pan that the crankshaft splashes to lube the bottom end. And being air/oil cooled means internal temperatures will rise dramatically with reduced oil volume.
Linuxology, with a quart left in the sump, you may have dodged a bullet on this one. That the engine was sounding normal when you stopped is a good sign.
BTW, I think your rear braking issue was probably a combination of oil on the rear disk/pads and on the tire as well. You've got some cleaning up to do :(
So, did you determine how/why you lost the oil? Loose filter/drain plug/fill plug?
Sounds like you dodged a bullet...good to hear it.
Blockhead, in the first post he said he had 2 gaskets on the oil filter. So it didn't seat correctly. I guess when he changed the oil the gasket stuck on the engine and he didn't notice.
This clearly illustrates why you should carefully wipe down the mating surface on the engine to get it clean before seating the new filter.
Had he done that he would have noticed the old O-ring still in place.
Fingers crossed that no engine damage was done.
Intermittent Oil Light on with smoke from exhaust means STOP!!! You are very lucky, forget the motor, you could have gone down with oil on the rear wheel. Your not going to notice any short term effects if the motor is quite with no unusual noise.
Like popgun said, remove the rear brake pads and sand them down, if there is any sign of discoloration replace them. I'm sure your problem is not the loss of brake fluid.
I remember a similar situation concerning a Honda service bulletin and the first model Honda CRV. Seems that the oil filter gasket had a tendency to adhere to the engine block when the oil filter was removed. Techs were advised to check before installing a new filter.
My guess is that no engine damage has been done (modern oils being so good) and a good cleaning of the rear brake, tire and new rear pads and should be okay. Fingers crossed for you.
Ahh right you are...my reading comprehension skills hadn't kicked in before my coffee fix this morning.
Rode the bike for 15 minutes this morning. So far the engine has shown no issues. Got her up to speed and a variety of situations with stops, idling, highway speeds, low speeds, etc. No issues with the engine. Brake fluid looks to be up to level and maybe I hallucinated in the heat of the moment. My first thoughts initially was that I lost rear brake, but it was more than likely oil which caused rear braking issues. My rear brakes are not working still, so I will look into that later this afternoon as I got other personal matters to tend to. I feel extremely fortunate. Thanks for everyone's insights. She seems to be o.k., but further investigations are needed. Next is that rear brake issue.
Once you get oil in the pads, you really need to change them. Really. Go buy new ones today. They are not hard to change.
I am really glad your bike is OK otherwise. Dodged a bullet there!
Like popgun said oil will impregnate a brake pad effectively ruining it. However, I would pull them and examine them and see if a little filing or belt sander time would clean them up. nOt optimistic but worth a shot.
Would third what the above two say as well. Also, when you clean up, make sure you are using something like brake cleaner or the like (but not on painted surfaces of course) you really need a strong solvent to get all the residual oil off everything.
