the Ferret
Ferret do you mind giving me a crash course on fitting a "not stock" tire on a wheel like ours?mvk24_imp said:Ferret do you mind giving me a crash course on fitting a "not stock" tire on a wheel like ours?The ferret_imp said:There is a thread “Pirelli Angel GT vs Bridgestone BT 54” or something like that where I posted a pic of the Angel GTs currently on my bike with 10,300 miles on them. I also have a new pair in the garage for when these wear out. (im also running them on my NC) but they do not come in stock sizes for the CB I dont believe. I’m as pleased with them as I could be considering the PR 3’s are no longer available. A very satisfactory replacement.
I've only ever used stock sizes on my bikes. I wouldn't really know how to look at a tire size and know it will or won't fit other than following the stock spec and the rim size is obvious but the other 2 numbers still confuse me.
I dont think I would mind a slightly larger tires both front and rear if it didn't cause issues? I know guys here have gone up in the rear. Not sure how that affects handling or payload limits?
Sorry been out all day. Im no tire expert either and in 2013 I also questioned going up in tire sizes. A couple of forum members had done it, using 120 front and 160 rear. They had no issues so I mounted up a set of PR 3s on my 2013 and saw there were no clearance issues for myself.
One benefit I saw on the rear, with the 140 I could run them all the way to the edge. With the 160, try as I might I always had some rubber unused (aka a chicken strip) which I felt gave me a little extra safety measure.
So I have been running 160s on the rear for 10 years now ( approx 80,000 miles on 2 CB,s) and mostly 120s on the front.
Im no roadracer but others will vouch I can ride pretty quickly and pretty smoothly. I dont always ride like a grandpa in other words. The larger tire sizes handle just fine. As far as payload limits they have to be greater than with smaller tire sizes I would think, but to what extent I have no idea.
If quality tires came in the stock sizes Iwould have no issue running them, but I also have no qualms about running 1 up sizes on the CB.
