My anti lock non anti lock brake
The rear brake is doing lighter duty but certainly if you had a failure of the front brake you'd what want to be able to stop the bike.
If the dealer says differently then I'd find another dealer.
How about a defect in the master cylinder?
Gentlemen,
A number of things are possible, but some are far more likely than others so those are the first things to look for. Air in brake lines is the most common cause of weak braking performance if the pads aren't worn out so I would start there. A technician friend once told me, "If I hear hoofbeats here in Arizona, I'm gonna look for horses, not Zebras". All the best.
Chip
Yep, either the pads aren't being squeezed on the rotor well enough and the prime suspect is air in the line, or they're being squeezed plenty good, but there's not enough friction from pad to rotor. Doubt pads are glazed or worn, so if squeeze is good, then contamination is the likely suspect.
Sure would be easy for an over zealous setup tech to splash a little chain lube on that nearby rotor, or for a rotor anti-rust coating to miss being removed at the factory, or somewhere down the line.
Sure hope it gets sorted out for those who aren't getting normal rear brake operation.
The ferret_imp said:
Took my ST out for a 325 mile spin today ( rear brakes on it are awesome)....for a hotdog lol. Drove from one side of Ohio durn near to the other to meet a riding buddy for lunch at a Sonic. tried the new pretzel bun hot dog with cheese and bacon, tater tots and sweet tea. Dog was just ok, couldn't taste the bacon. Tater tots and sweet tea were great. Any excuse for a ride!
I think you all might be right. It's under warranty so I will let them bleed it.
Thanks. Now you have me thinkin' how fun it'd be to ride to the other side of WV and try that "Hillbilly Hot Dog" joint. :idea:
I'll meet you there.:D
After reading all the questions about braking I had to go out and try mine. I have a non-ABS model and my brakes have been great but I do balance them and wanted to isolate the rear system.
At 40 mph I can lock the rear pretty much at will but it does take some pressure. On a wet road or loose surface I think it'd be much easier to do.
Stainless braided lines are one of the mods I have high on my list and they would really help the system.
Had a try tonight riding home and had no issues locking the rear brake on my Australian 2010 model. Needs a bit of a push but it's probably set up well for a panic braking situation.
Well yesterday my brother and I pulled my pads, took a mill bastard file to them, then some heavy duty sand paper in a figure 8 pattern, blew them off and reinstalled. While the pads were out, I also scotch padded both sides of the disc again. Then I took a ride and did the 45 to 15 mph rear brake only thing about 5 times. Result : It's a little better, but certainly not what I'd expect.
I may stop at the dealership and let one of their techs take it for a ride and see what he thinks.
BUMP!
What did the dealer decide was the problem, if any? We should note that locking up the rear brake should be avoided and if you do lock it up you keep it locked and ride it out to avoid a possible loss of control should you release the lock.
My new 14 standard never locked while I practiced quick stops. This might be because I use the front heavily and the back lightly but in almost 20 or so quick stop practices, it never locked, which I thought was spendid. The MSF school Suzuki 250 bikes could be locked easily in the back and I practiced riding it out with them, but the CB never did a lock...again this might be because the CB brakes, both front and back are both hydraulic and both seem to have enough flexibility to allow you to gently sqeeze them progressively so you can keep from going into a skid. But still, it seemed like my rear brake was effective but still prone not to lock and I pushed it, it seemed wonderful to me and so I wonder if this is by design, I think so. I hope so.
I have a tendency to use the front mostly and the rear lightly to support them, or not at all if going downhill where all weight is on the front, or conversly solitary use of the back mostly in slow parking lot manuvers, the front not as effective at slow speed as the back. For example, I will use mostly the front to slow from highway speed and then under 10 mph go to the rear to come to a smooth stop, and the rear never let me down for that purpose. This might not be correct but seems to work for me and I remember the MSF instructor warning us not to use the front only on slow speed stops because it will cause the front to dive and you can lose it.
CIP57_imp said:
I was thinking how well the brakes perform on this bike. All my recent Honda's have linked brake systems ( non abs ) and don't like any of them. Braking on linked systems hard in a turn will stand you straight up, horrible feeling. You could never low side with them.
My rear brake is very good, it locks right up if i want it to allowing me to low side in case of danger. The rear brake on this bike is much better than my ST, CBR or XX all with linked brakes. My rear has a very strong bite but its new, we'll have to see when we get some miles on her.
Allowing you to low side? From everything I've read, brake lock-up, and consequently low siding is something to be avoided, and it's always best to stay upright and scrub off as much speed as possible.
The rear brakes come into play mostly during slow speed maneuvers and through turns - they help to stabilize the bike. As previously stated, most of the stopping power comes from the front.
In normal or emergency stopping situations, front and rear should be applied together.
Quote:From everything I've read, brake lock-up, and consequently low siding is something to be avoided, and it's always best to stay upright and scrub off as much speed as possible.
Point should be highlighted. Avoid locking the back brake because you have lost all the ability to change direction, will slide where it decides to slide and should you panic and get off the brake before the bike comes to a complete stop, the back wheel will spin up faster than the front wheel since all the mass has shifted to the front now leaving you with little traction on the back, and the rear will slide either way with great force causing you to lose control completely and in a very light sports bike even flip.
So while practicing quick stops with the small MSF provided Suzuki, sometimes the back would lock and I was judged on whether I could remember to keep it locked, should that occur, until coming to a full stop. The great quick stop is one that you do without locking either wheel, 1) squeeze the clutch and roll off the gas, 2) squeeze the front brake and "squeeze" the rear at the same time with the foot pedal till just before either lock and at the same time 3) s hift into 1st and 4) put your left foot down as you come to a stop.
Emphasis on "squeeze" rather than grab. Smooth and progressive action on clutch, gas and both brakes.
On a side note, I found the CB1100 is easier to stop and get going smoothly than the little Suzuki 250, which was a nice bike btw. So sometimes the bigger and better bike is in some ways easier to ride than a smaller bike. Weight being a negative on the CB side when suggesting it is a good beginner bike.
I'm an old dirt riding guy, first thing i did when i get the CB is to see how the bike reacts during full lock up of the rear wheel, how it changes direction. Leg off the peg on the ground for balance she spins right around. There a certain point of no return though, which would be a nasty high side if you don't keep the bike low enough. Not recommended if you have any fear going into this procedure.
I'm an old dirt riding guy, first thing i did when i get the CB is to see how the bike reacts during full lock up of the rear wheel, how it changes direction. Leg off the peg on the ground for balance she spins right around. There a certain point of no return though, which would be a nasty high side if you don't keep the bike low enough. Not recommended if you have any fear going into this procedure. I had an incident once where an idiot in an SUV turned left right in front of me and I clamped on the brakes. My rear locked up and I slid sideways. Fortunately I didn't release the brake and I was able to ride out the slide and recover, but it was a butt-puckering moment for sure. That's why I'm now happy to have a bike with ABS.
Quote:Which is it?
Hahaha just realized how that sounded. I meant when I tried and pushed hard it will lock up and skid. When normal pressure is applied it will not lock up and catch you by surprise is what i meant. Meaning when i want to lock up the rear tire I know how.
Gentlemen. I've been meaning to start a thread about my anti-lock brakes, but it looks like we've already got one going. My rear brake works great! It has a lot more stopping force than my VFR and I am really happy with it. My concern is the functioning of the anti-lock system on the rear brake. I used it in an emergency (when an 18 wheeler did a right turn across my lane without using his turn signal) and the wheel locked easily, but the anti-lock felt like it was cycling at about 1 Hz, which I find rather odd. I tried locking the rear brake two additional times in a parking lot with the same results - the wheel will instantly lock, then the anti-lock solenoid valve feels like it is cycling at approximately 1 Hz. I know from experience that the front brake anti-lock system on this bike cycles at approximately 60 Hz, which seems to be what cars I have driven operate at. Does anyone know what the rear brake anti-lock solenoid frequency should be?
I've had no trouble locking the rear wheel in the quick stop portion of the license exam (~15 mph). Haven't tried it at speed, but it may be harder because the weight shift toward the front is probably a lot stronger when you're traveling faster.
The rear brake isn't meant to be used for emergency/panic braking, or even under normal braking situations. Majority of your breaking comes from the front wheel. When you brake with the front, the weight transfer causes the front tire to be pushed into the ground, increasing your contact patch and the available friction for braking.
When you brake with the rear, you can potentially lose traction much easier. The rear brake is meant for conditions where the front might break loose, like in the rain or on gravel. Or if you're racing, to set up the bike's weight for a turn.
If you're riding on a normal day on the streets, you should be pretty much exclusively using the front brake. People think that they should use the rear to avoid going end over end or braking the front loose, but it would take being extremely ham fisted to do that, I assure you. And attempting to use both in an emergency situation is just as bad. Trying to modulate two different brakes at once requires far too much processing to be instinctual.
Stick with the front brake, except in times with low traction. :)
You should be covering both brakes all the time. Burning off speed by using "some" rear allows your front end to stay less compressed with better mobility.
I use my rear all the time during normal braking, both brakes will have equal pressure until the final 15-20 MPH and the front will do the work. By covering the brake (always having 2 fingers on the brake) you are less likely to grab a handful in emergency situations.
Rear braking on tracks are used only to stabilize or straighten out the bike while trail braking with the front will cause yaw or lean, so they both have there benefits.
