^^^ I was going to ask the same exact questions!Tripod_imp said:^^^ I was going to ask the same exact questions!HikerToo_imp said:Can the TSR Air Funnel be used with the stock air filter (K&N not needed)?
http://shop.tsrjp.com/item/IS00008N00770.html
http://www.samurider.com/?p=16803/#itemImage
Also, does this "funnel" replace the OEM side plate or did you need to cut out part of the plastic?
And to confirm you can use the Staintune with the Motogear Tit header?
http://www.samurider.com/?p=15371
The Motogear titanium header fits a stock muffler, so any aftermarket muffler that fits a stock header will fit. The gold funnel replaces the stock cover, and both K&N and stock air filters have same dimensions and both fit the gold funnel but the K&N is better flowing so its sorta needed to reap the benefits.
